Results 1 to 5 of 5
Thread: VIA M10K fan noisen?
    FLAC J187's Avatar
    Nov 2004
    Boston
    Oops, meant Noisy!
    I just installed my new VIA M10K for the first time just for a power trial. No screen, no HDD yet. Just simply to test the psu and the board in its new custom mounting place in my GMC 1500 Pickup. The problem? I had not anticipated that the fan would be as loud as it is. It kind of shocked me to be honest. I think its going to be a problem whereas I had to mount the board directly below the cupholder in the console. I don't have easy access to play around with the BIOS for the board, does anyone know if there is a setting to regulate the speed and how the board would respond if I lowered the fan speed as far as heat goes, this is my first experience w/ this board and w/ Mini ITX in general. Other suggestions are welcome. THanks.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Replace it with a quiet fan or maybe put a variable resistor in line..? I also heard that the program "speedfan" can control the speed depending on temperature, but i don't know if it would work with your board.
    Jan 2007
    Columbus, OH
    It must be a bad fan because I have the same board and I can't even hear mine spinning.
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Quote Originally Posted by mdlesk View Post
    Same here.
    I installed my carpc into my pet Kangaroo, mate.
    FLAC J187's Avatar
    Nov 2004
    Boston
    I doubt its a bad fan...its not bearing noise or anything, its the sound of wind tunneling. Really, you guys can't even hear yours? Not even if its right in front of you andnot in a case?
    Tree, thanks, but I haven't seen any quiet replacements for the Mini ITx boards...
    Please help.
  1. Cold weather, chassis cooling fan problem
    By blazini in forum General Hardware Discussion
    Last Post: 11-08-2006, 07:55 AM
  2. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
  3. LED Fan
    By EBFoxbat in forum General MP3Car Discussion
    Last Post: 11-11-2004, 04:46 AM
  4. Do you need a very compact graphic fan controller?
    By more mods in forum LCD/Display
    Last Post: 09-24-2004, 07:17 AM
  5. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
