With the dschmidt shutdown controller (no longer available), it takes its cue from the accessory position on the ignition key.
Instead of wiring this to the Acc wire, do you think it will work if I wire it to either my (unused) Amp Remote (0.3A) wire or my (also unused) Power Antenna (0.1A) wire?
I'm thinking, that way, I can relenquish PC power (startup/shutdown) control to my head unit instead of my ignition switch.
~m
