Results 1 to 10 of 12
Thread: Question about Shutdown Controller connection
    Aug 2000
    Abbotsford, BC, Canada
    Post Question about Shutdown Controller connection
    With the dschmidt shutdown controller (no longer available), it takes its cue from the accessory position on the ignition key.
    Instead of wiring this to the Acc wire, do you think it will work if I wire it to either my (unused) Amp Remote (0.3A) wire or my (also unused) Power Antenna (0.1A) wire?
    I'm thinking, that way, I can relenquish PC power (startup/shutdown) control to my head unit instead of my ignition switch.
    ~m
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
    Aug 1999
    Upper Marlboro, MD 20772
    Cool
    It should, cuz it just senses when voltage drops if memory serves me right.
    abcd-1
    Aug 2000
    Post
    True, but if it normally pulls the signal from the ignition, I'm wondering if it'll pull too much current from the head unit wire. Anyone know how much current this lead draws? More than .1 or .3 Amps?
    ~m
    BC ROCKS!!!
    Oct 2000
    Vancouver, Canada
    Post
    It draws very little current. All it wants is the 12V signal to switch a relay. It couldn't be more then 300 mA... That's ALOT for a relay.
    If it helps, I have a 1A fuse on my ACC line that goes to the back and it turns on my computer relay power and two Alpine V12 amps and it's never blown.
    95 Honda Civic DX Coupe - In Progress
    mp3civic site
    Jun 2001
    San Diego, CA
    Post
    If you connect to the power antenna.. it will only turn on when you turn the head unit to the radio..
    Aug 2000
    Post
    Originally posted by Jargin:
    <STRONG>If you connect to the power antenna.. it will only turn on when you turn the head unit to the radio..</STRONG>
    Ahah! That may very well be... Good point. Thanks, Jargin.
    Well, since I won't be using the Amp Remote lead (can't afford an amp ), I'll try that one. Thanks, guys.
    ~m
    BC ROCKS!!!
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Post
    BUT.....the blue antenna wire is also used a the remote-amp turn-on. That would mean that the amps turn off when you switch to CD....and I know that doesnt happen.....
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
    May 2001
    Question
    why do you say that it's no longer available? i just bought one last week
    Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
    Mar 2001
    Post
    They're no longer available.
    dschmidt says he's out of them and he doesnt' sell enough to make it worthwhile to order another batch. He'd have to order so many up front that it'd take him years to recoup his investment.
    :/ Sucks. I need a shutdown controller and now I can't get his.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
    Aug 2000
    Post
    Hmmm... Anyone besides me detect a "reverse-engineering" opportunity here???
    ~m
    BC ROCKS!!!
