Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: EPIA CN13000 Don't Hibernates, HELP
  1. #11
    Jan 2007
    good that you've eliminated the RAM as culprit. Just to be on the safe side: after trying the new Hyperion, change BIOS settings to "Fail-safe defaults" and to "Optimized defaults" if both fail (*) we can then look at your hard disk. Disable hibernation as Curiosity said and run diskcheck (thorough scan & fix) followed by defrag. Enable hibernate again afterwards.
    If you still see the same issue reinstall WinXP (not nLite please) and select NTFS _normal_ format during setup.
    (*) Apparently some of VIAs "fail-safe defaults" are not as fail-safe as their "optimized defaults"...
  2. #12
    Jan 2007
    No OC Curiosity, I'm installing hyperion Now, If this don't work I'll try what you said
  3. #13
    Jan 2007
    Hyperion didn't work
    Change optimized and failsafe...didn't work
    Disable-enable Hibernation didn't work
    So..I'm trying to install XP in an USB HD.
    WTF....I can't install into a USB HD, another blue screen during instalation :'(
  4. #14
    Jan 2007
    some new ideas?
  5. #15
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I still think it's memory.
  6. #16
    Jan 2007
    Did you run disable hibernate and run diskcheck ?
  7. #17
    Jan 2007
    Both the memory and the HD are 100% new, I also tried a different RAM stick.
    Tomorrow I'll do defrag and chkdsk
  8. #18
    Jan 2007
    Quote Originally Posted by djrod View Post
    To be thorough do it in this order:
    a) In the BIOS select "Load Optimized settings" & "Save"
    b) disable hibernate
    c) reboot
    d) chkdsk C: and enable all options for fixing/checking
    e) defrag
    f) enable hibernate
  9. #19
    Jan 2007
    I changed the HD for another HD and now hibernates!
  10. #20
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Thats ******* weird.
    08 Lincoln Navigator www.mobiteklink.com
  1. FS: MANY MANY EPIA boards and 2.5" DRIVES!!!!
    By UrbanSoot in forum Classified Archive
    Last Post: 02-13-2007, 03:14 PM
  2. Normal AMD/Intel system or VIA Epia system??
    By ironic in forum General Hardware Discussion
    Last Post: 12-08-2005, 08:07 AM
  3. Pentuim M on DFI Vs. Epia Worth it?
    By alti in forum General Hardware Discussion
    Last Post: 12-04-2004, 03:05 AM
  4. Original Epia VS Epia M
    By MeanGT in forum General Hardware Discussion
    Last Post: 09-23-2003, 04:25 PM
  5. Epia M and Epia 800 differences
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-20-2002, 11:50 PM
