Results 1 to 10 of 12
Thread: founda am/fm/tv tuner/amp!
    May 2002
    Sef'Kylar
    If you've been looking for a way to get rid of your head unit and still be able to listen to the radio this may be the solution.. not only that but you get tv too! It has a remote and a/v ins and outs $299 shipped.
    I found this am/fm/tv tuner/amp while I was looking for a different item. I may get this instead though
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Apr 2002
    socal
    kinda costy dont you think? i am running without a head unit with the usb tv/fm tuner by wintv and it works fine.
    Jul 2002
    Boston, MA
    Sounds like it's pricey because of the built in amps.
    I already have high end amps, and don't need any more.
    If anyone see's the identical thing without the amps, let us know!
    Thanks...
    -Mario
    Apr 2002
    South Coast, UK
    Er, isnt that basically the same as a head unit but without any front panel controls? I can understand people getting rid of their head unit to control radio through the comp, but not getting rid of the head unit for a seperate box!
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    Jul 2002
    Boston, MA
    It's a good if you want to use a motorized LCD in your DIN.
    I only have 1 1/2 DIN in my Chrysler, otherwise I would concider keeping a head unit...
    -Mario
    May 2002
    Sef'Kylar
    RE: "Why would you want this?"
    Well if you don't have an amp.. and you don't have room to put a head unit in your dash and you still want to be able to listen to the radio (wow this is me!) then this is a solution
    It's basically a headunit that is not in your dash I suppose.
    aka Kumaneko
    Feb 2001
    Somerville, MA
    OK, so how do you change the stations? Does it have some sort of PC interface?
    Twostep
    May 2002
    Sef'Kylar
    If you followed the link you would notice it is controlled by remote.
    aka Kumaneko
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Saw Video in, but not line in audio?
    How would you get the DVD audio, or in our case PC Audio into the unit?
    And you could probably control it via an IRa/IRman through onscreen buttons if the remote is Infra red.
    4x4 in a turbo stylee.
    Apr 2002
    South Coast, UK
    But a tuner card and decent amp would probably work out a fair bit cheaper, and be higher quality.
