the best way to do this for you, and easy is do use an inverter... figure out the watts on your psu then search for 1
So Ill probably get flamed for asking this, but Im trying to complete, or begin the Carputer project but Im working with a REALLY tight budget thanks to the cops in this town. I have a 4 year old 1.5Ghz P4/256 SDRam/60 Gigs/Dual bays/Radeon 9000 that I use only when I come home from school. I wouldnt mind dropping this and harnessing it into my trunk. Its smaller than the ATX Mid tower that I built. I was wondering if theres anyway I can convert the power supply so it will work through the cars 12volt and hook up a shutdown controller to it.
I disagree. An inverter setup that is correctly wired will be just as much as the compareable dc-dc.
The system you say you have the P4 1.5 is not as power hungry as the newer P4s, so I think that and the mobo will be able to be run off of a M2 or a Opus 120.
As for the video card, leave it out. I am sure that mobo has onboard video, so just use it. If it doesn't get a cheapo $15 pci/agp video card. Not pci-e because I dont even think that was around with the 1.5's, but regular old pci.
Think about it this way: A lot of people use via boards. The one I have is equivalent to about a 700-800 Mhz P3. I use onboard video and sound. And it is speedy. Playing music, videos, and GPS do not require much cpu power. TruckinMP3 is running a Celeron300A!!
So dump the Radeon.
And I don't know what you mean about dual bays?! Dual optical drives, harddrives, empty slots?
1.9in x 2.9in -- 47mm x 73mm
How much of a hassle to remove an optical drive? It is wasted power drain. And you might think that a drive doesn't use much, but a single full sized optical drive can draw 1-2 amps by themselves. On the M2, one drive eats away 10-20% of your available power.
The M2 and the Opus use standard desktop ATX connectors.
SDC = Shutdown Controller
DC-DC = Efficient PSU that goes from DC (Car Battery) to DC (what computer uses) opposed to the innefficient and wrong way of DC (Car) to AC (Inverter out and square wave for the cheap crap ones) back to DC (Computer PSU producing heat and inferior voltages due to the crap square wave input).
The M2-ATX and Opus 120W are 2 dc-dc psu's sold in the store or eBay that take the cars powe runregulated, and regulate it as well as have sdc's built in. There are many others as well but they go up in price.
Unless your the PC/mobo you had was from DELL. If it has 20 PIN standard ATX power supply, you can use ANY DC-DC mention by 2k1Toaster
Take sometime read the FAQ and do some searching. Most/all your question you think of going to ask has been answer. It and educate reading that can save you lots of money down the road.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
