IDE to USB![]()
So im planning on running a slot load cd/dvd drive up front on my dash but my computer will be in the back. How would i connect the two? can you run and IDE cable the whole distance? Also, i will have a USB hub in my glove box, could i use an IDE to usb adapter and run it like that? keep in mind the hub is not powered. Thanks...
'08 VW Rabbit S 2.5
Carputer Progress:
Design:[][][][][][][][][][][][][][][][][][] 100%
Fabrication:[][][][][][][][][][][][][][][][][][]100%
Installation:[][][][][][][][][][][][][][][][][][][][][][][][][] 80%
In trouble...
IDE to USB![]()
It's been a while...
and there would be no problems running git through an unpowered hub?
thanks for the response
'08 VW Rabbit S 2.5
Carputer Progress:
In trouble...
you will most likely have problems with running it off of an unpowered hub. Read all about it but I suggest you get some power to that drive.
^ and run power all the way to the front? im thinking of scraping this idea and just using an external hard rive in the back...
'08 VW Rabbit S 2.5
Carputer Progress:
In trouble...
