Results 1 to 5 of 5
Thread: power vga cables
    Dec 2004
    Howell, NJ
    power vga cables
    hey guys and gals,
    i know that with car audio you dont want to run your signal cables along your power cables because of nose problems....does the same apply to the vga cable or is it ok to run it next to your power cable? same thing with usb?
    thanks
    mike
    2003 Steel Blue PT Cruiser GT Autostick, Mopar BOV, K&N FIPK, Dual Exhaust, Boost Gauge.
    ICE: 2 12" Infinity 1230W, JBL BP1200.1, Infinity 6000CS, JBL P80.4, Sirius Starmate.
    http://www.cardomain.com/ride/2314583
    Mar 2006
    Colorado, but Canadian!
    yes the same thing applies. with vga cables you will get visual noise such as wavy lines on your screen that move faster with higher rpms.
    So power wires on 1 side, and signal cables on the other side.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Calgary, Alberta
    I found it easier to run the power wire through the edge of the headliner, just above the plastic moulding near the top of the windows.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jan 2007
    New Jersey
    Quote Originally Posted by 2k1Toaster View Post
    What about a perpendicular pass. My power wire is coming directly from my battery and will cross my speaker wires. Will this cause any noticeable interference?
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    If you cross data and power at a 90deg angle, it'll be fine. As long as they aren't running parallel.
  1. Hardware Review: Provision 8" 16:9 VGA Touchscreen
    By lightman in forum The Review Palace
    Last Post: 06-15-2009, 09:02 AM
  2. FAQ: VGA vs. Composite (Video) Screens
    By cproaudio in forum The FAQ Emporium
    Last Post: 12-28-2007, 12:45 PM
  3. WTB - Lilliput VGA Cables!!! My Dog ate mine!
    By brain21 in forum Classified Archive
    Last Post: 12-27-2006, 08:58 PM
  4. FS: Liliput 7" TS, Audigy2 NX, USB Cables, VGA
    By joshuaeric in forum Classified Archive
    Last Post: 06-18-2006, 06:24 PM
  5. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
