Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Relocating a/c vents/controls and such...
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Okay I just bought a new Jeep Grand Cherokee.
    After driving around in my old SUV for about a year with a laptop on a jottodesk, I've decided to get my own carputer underway.
    Im my car (suv whatever) I don't have room to put an in dash LCD (or preferably touchscreen) display in unless, you guessed it, custom fabrication work. This will entail remodeling the dash which consists of (top to bottom) the haed unit for the stereo, a/c vents, a/c controls, and finally an ashtray. I have ideas on WHERE to move the controls, but I'm looking for ideas on what to do with the vents? I suppose I could have someone custom fabricate some new ductwork for the vents and move them to the top, but the thing that is going to get me is all of the custom work to the plastic panel. I don't see how I could get around building a new one.
    Okay so my questions... finally.
    What's the best method for constructing a new panel so I may mount a display in it? I was thinking about buying the panel off of a junked/wrecked one and trying my hand at fiberglass molding (I don;t even know what you call it). Does this seem like a viable option?
    How about the ductwork? Has anyone ever done this when relocating the vents? What did you use?
    How about just general suggestions for AC control locations? I was thinking about sticking them in the center console on a plate of some sort (haven't thought too much about what I will actually need to mount them).?
    Any suggestions for a newbie undertaking a project such as this?
    Dec 1999
    Buena Park, CA
    Something to keep in mind is that recent model cars tend to use vacumm in order to effect the changes in where air is directed.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    I guess I missed the point of your post. What do you mean? That I should keep the same diameter ducting and make sure there is no leakage?
    Dec 1999
    Buena Park, CA
    Depending on the distance involved, you might need larger diameter tubing for the vacuum lines. You will also have to deal with however many are back there, could be quite a few.
    As a side note, one of my vehicles actually had a problem with the vacuum line for climate control, and it was a nightmare to get the dealer to fix it correctly (it went back 3 times, had to get the service manager involved, and then they had it a week before it was finally fixed!). If your system is anything like mine was, it could turn into a huge headache trying to get it to work properly.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    hrmph! I don't thik I want the headache... but I want a flush mount LCD.. I don't want a screen mounted to the consile or anything... that's what I was trying to get away from... I'd just throw the old jottodesk back in the new car...
    Well I am learning that what I read is true. Lots of planning and replanning. I'll be replanning. Thanks for the input.
    Jul 2001
    Richmond, VA USA
    Just a thought... if you are going to make an entire new dash yourself... you could always make the section where the A/C controls and such a little taller (and mold it to rise smoothly to that spot) then you could just make that big enough to put the A/C controls there (no major move so the vacuum lines (if applicable) should be fine). Or you could always try to go with a smaller LCD, but that's no fun right... let me try to do some quick ASCII of what I am talking about with the dash... if it turns out bad i'll do a quick drawing and attach it.
    _/|______|\_
    | |_______| |
    | |_______| |
    the blue section is where your A/C controls are currently, the part above that (looks like this: /|______|\ )is the new part you would create and move the controls to... and then you move everything else which wont give you problems and put the screen in, sounds so simple right?
    BTW this thing looks legible in preview, but if anyone has trouble viewing it let me know... I can draw a decent picture if need be, I think this should convey the point though.
    -Josh
    Edit... I was just re-reading your post and I wasn't thinking straight before... I thought your A/C controls were up top (mine are, I guess I that's why) anyway same thing as before, but move the new addition to the bottom, of course if you don't need the ashtray you could utilize some of that space and just move the controls down enough... but again this all depends on how much you want it vs how much work you want to do. Also you might want to look into a new headunit that has a screen that folds in/out (your stock one will probably not have any aux inputs...just another reason)
    Josh Karger
    By reading this post you agree to overlook all grammatical, spelling, and typographical errors! ;)
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    thanks for your reply... yeah the ashtray can go. If I were to move the ac vents in the space where the ashtray is (that's put them at the very bottom) that'd give me some room to work with... probably enough for a Xenarc in the dash.
    The problem lies in the fact that I don't have a clue what I would do with the ac vents.
    *** ADDED ***
    and where I live (Texas) it's not really an option to ditch them. Summer lasts about 8 months here.
    Jul 2001
    Richmond, VA USA
    Yeah I agree, I live in Virginia and I still wouldn't want to be without A/C and mine sucks anyway... But by what do you mean not know what to do with the vents (do you mean extending them or what?) BTW do you have a picture of your dash or one like yours from the internet somewhere... by the way you've explained it, is it safe to assume the dash looks something like this: http://www.edmunds.com/roadtests/com...rstack.350.jpg
    I'm sure the picture=1,000 words equation goes here at MP3car... post some pics and someone is bound to e able to give you an idea on how to move the stuff around.
    -Josh
    Josh Karger
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    What I meant was where I would place the vents in the whole scheme of things. Meaning extending them, re-routing them, whatever.
    Good Idea. I'll take some pics tomorrow, but the pic you posted is 100% dead on. I'm thinking (top to bottom) touchscreen display, head unit (I still like my CD's) ac vents and ac controls. Or maybe touchscreen, av vents (wouldn't have to move them), head unit, then A/C controls.
    I haven't yet taken the panel off (just been busy) but I think if I do I might be able to move the A/C vents to the bottom where the ashtray and cigarette lighter go. I think, or hope, there might be enough play in the hoses.
    What I'll probably do (I've been reading LOL) is make a new panel using fiberglass and a panel off of a wrecked grand cherokee. That way I can cut stuff off and replace it where I need it (like the AC vents) and fiberglass it back in - throw some bondo on - sand it - and paint it.
    This would be a sweeet setup. Well my journey has begun. Expect a buttload of questions from me in the very near future. Thanks in advance!
    Dec 1999
    Buena Park, CA
    Personally, I would put the touch screen in the current stock head unit location, and relocate the head unit down where the ashtray, lighter, etc. is. Should be the best solution for the least amount of work. You are planning on using your 'puter most of the time, right? Also, if need be, you could pick up a standard DIN head unit, if you needed something smaller than the stocker.
