Results 1 to 9 of 9
Thread: EPIA-M CPU 100% problem
    Jun 2006
    I have a EPIA-M 1000 with 512mbDDR and 40gb 4200 and just freshly formatted with XPsp2 and updates. I only installed drivers for the board and video codecs of CCCP, divx, Ac3. I'm using VLC and MPC both seem to have "lagging" problems as well as slow within windows.
    Here are some Screen Shots of what is happening. Basically its at 100% just by playing a video.
    100%
    Only 20 things running.
    Any ideas on why it is so slow? Maybe the harddrive as its only a 40gb 4200rpm.
    Jun 2006
    Fake edit...can someone move this to general hardware?
    Kthax
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    It's not so much how many services you have running, it's how much CPU they're collectivley using that slow the performance.
    Looking at your taskmanager screenshot, it's Mplayer that's sucking the usage of the CPU (it's on 98%). You mentioned that VLC was laggy as well. Try running VLC without mplayer open and see if that goes up to around 98 as well. If it is, then it's possibly somethign common to both programs ie. codecs.
    I installed my carpc into my pet Kangaroo, mate.
    Jun 2006
    Quote Originally Posted by NiSlo View Post
    I know its mplayer, VLC, Winamp that are pulling the CPU. I'm just confused why its pulling so much? Is it because its mpg2 decoding? The m1000 should be able to run these programs alot more efficent right?
    Registered User
    Dec 2006
    Scarborough, Ontario
    uninstall your mpeg codecs..and just use your comp and see if that makes a dif. it cant be your cpu..any problem with your cpu and your comp shouldn't even be functioning...then try and install a codec pack onto your comp..io have the same cpu..160gb hd and 1 gb of mem..i play mp3s and gps at the same time..im using roughly about 53% cpu then..the max i hit is 78 ish and thats when i change songs..i know my specs aren't similar to your but in the end..your using way to much cpu..and it really shouldn't be that high..
    DONT reinstall windows xp..eliminate programs one at a time beforehand...
    Nov 2006
    Is the usage the same when you're watching a video as it is when listening to music?
    I've got the m10000 with 512mb RAM and I had no issues what so ever. Granted I didnt check it's CPU usage, but it was fast, responsive and smooth when I used it.
    FLAC jbors's Avatar
    Nov 2003
    I would check if you have proper directx installation. Overlay settings in particular.
    Car pc integration with ease
    Car mediacenter
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Are you using an external USB soundcard? I know when I switched to a USB soundcard over a PCI one on my M10000 mp3 playback was close to 50% and video playback was super high. DVD, forget it. I was able to do it all with a PCI soundcard and an IDE dvd drive with much lower CPU usage.
    Jun 2006
    hmm...still have the problem
    Things I've tried.
    Different ram
    Fresh XP format
    Install of windows updates all over again
    No codecs
    Still uses 100% alot....like doing windows update.
  1. Strange power suplly problem.
    By seninha in forum Power Supplies
    Last Post: 10-22-2006, 06:32 AM
  2. VIA EPIA V Bootup problem.
    By Nomad in forum General Hardware Discussion
    Last Post: 05-23-2005, 06:15 AM
  3. Serial GPS and Epia M9000 problem
    By mp3oplecarrier in forum GPS
    Last Post: 07-19-2004, 10:13 PM
  4. Problem testing VIA EPIA w/standard atx power supply
    By khufumen in forum Power Supplies
    Last Post: 11-15-2003, 03:22 AM
  5. boot problem with epia m
    By jemmons in forum General Hardware Discussion
    Last Post: 10-24-2003, 07:16 PM
