Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Cooling Issues
  1. #11
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Use a powered hub. Run a length of wire from the carpc in back to the cd drive in front (for power regulation). I use the same wire to power my Xenarc.
  2. #12
    Jul 2007
    So, if I had the usb hub in the back it may work? because I had a 10ft cable, then the hub, then the cd-rom into the hub, and it still wouldn't work. and it is a powered hub.
  3. #13
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by jjohnston View Post
    Could be a low quality cable, or voltage drop on the powered hub. How are you powering the hub Have you tried another brand of USB extension cable? What are you using to power the entire computer in the car? Perhaps you are overloading the 5v rail of your PS witht he voltage drop on the USB cable?
    Michael
  4. #14
    Jul 2007
    I got a 160w power supply, its built for in car use. I've tested with a normal 350w power supply and have the same issues.
    -Joel-
  5. #15
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    -Joel-
    Please read my WHOLE post. Provide the information requested, or else no one can help. It's like calling a mechanic, and saying, my car is not working, I looked and there is enough gas, now what?
    Michael
  6. #16
    Jul 2007
    How are you powering the hub? Power Inverter with the hub pluged into that with the power cord that came with it.
    Have you tried another brand of USB extension cable? No, couldn't find any long enough other than this one.
    What are you using to power the entire computer in the car? 160w Power supply built for in car use.
  7. #17
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Which PS are you using?
    I would search for another USB cable and try that. How are you powering the inverter? Is the hub the only device plugged into the inverter. What is the power output of the inverter. Look on the back of the cube of the hub, and tell me what is says the input and output is. Check the end of the plug for proper voltage output. If the only difference between the working and non working setup that short USB cable?
    Michael
  8. #18
    Jul 2007
    USB hub = 5v 3.2amps not sure input output because its not listed on the unit. the powersupply is
    M2-ATX 160W Intelligent DC-DC PSU
  1. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 07:48 PM
  2. FAQ: Cooling Your System
    By Bugbyte in forum The FAQ Emporium
    Last Post: 10-03-2005, 04:09 PM
  3. Another Cooling idea from a dreamer...
    By Sillydipstixs18 in forum General Hardware Discussion
    Last Post: 07-28-2005, 11:10 AM
  4. cooling control panel
    By Sillydipstixs18 in forum LCD/Display
    Last Post: 05-23-2005, 02:36 AM
  5. FV24 Cooling Issues
    By slarty in forum General Hardware Discussion
    Last Post: 10-20-2002, 08:20 AM
