Results 1 to 10 of 18
Thread: Cooling Issues
    Jul 2007
    Cooling Issues
    Ok, So I've been doing an in car computer. Couldn't get it to work, so I took everything out, set it up inside and it worked perfect. Thought maybe my 160 watt power supply wasn't powerful enough. so I got a power inverter and ran the regular 350 watt power supply. worked for about 3 min, then same issues. Only thing I can think of is... maybe its just getting to hot. Its about 100 degrees outside today.
    This long story brings me to my question... How can I cool my computer well enough to work in this situation?? are there better fans or something. I'm just using the standard everyday fan that came with the processor 3 years ago.
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    It may be too hot to start, but once it gets going the processor fan should be enough to keep the chip cool.
    I'd look more into having the whole system cooler to start with. That's a lot more difficult than keeping the processor cool once it's on.
    Jul 2007
    Its strange. we just had a big storm, its like 75 degrees outside now. I turned on the computer, and I saw the bios on the screen, then the windows logo as it booted, then about when the windows desktop is supposed to show... the screen went black, then I got a couple flashes, then the screen shut off.
    -Joel-
    Dec 2004
    Wichita Falls, Texas
    list your hardware.
    Jul 2007
    I got an AMD Semptron 1.5ghz processor. 512mb ram, GeForce FX 5200 video card, Xenarc Monitor...
    I tried booting into safe mode. it will boot up no problem into safe mode. I tried changing the res in safemode thinking it wasn't compatible with the monitor. still nothing. but it will boot into safe mode.
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    This really doesnt sound like a heat issue, sounds more like something is set wrong....
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    Jul 2007
    yeah. its strange. I finally got it to boot, works great for a while. like 3 min or so, then it freezes up. I thought about reinstalling XP, but I don't know that you can do that using a USB CD-rom Drive.
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    Maybe it's a power issue, like not everything turns on when booted in safe mode. Your Sempron pulls about 62W at full tilt, which is pretty high (though it doesn't explain why it wouldn't boot with your inverter).
    You also might want to do a hard drive diagnostic to see if something's wrong there (random freezes and crashes can be caused by a failing hard drive). Turn on SMART and get something that reads the diagnostics, see what it says.
    That's all I can think of.
    Nov 2005
    Dallas, TX
    I have another idea, its stupid, but still an idea...
    If you have anything plugged in via USB, un-plug it all. Then try to boot.... And go from there. I have heard about people not being able to boot because of BT Dongles and USB Keyboards....
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Jul 2007
    I think I got it. I guess my USB distance is too far. If I plug everything in using short cables it works perfect. too bad, I wanted the CD rom drive in the front of the car. Oh well...
  1. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 07:48 PM
  2. FAQ: Cooling Your System
    By Bugbyte in forum The FAQ Emporium
    Last Post: 10-03-2005, 04:09 PM
  3. Another Cooling idea from a dreamer...
    By Sillydipstixs18 in forum General Hardware Discussion
    Last Post: 07-28-2005, 11:10 AM
  4. cooling control panel
    By Sillydipstixs18 in forum LCD/Display
    Last Post: 05-23-2005, 02:36 AM
  5. FV24 Cooling Issues
    By slarty in forum General Hardware Discussion
    Last Post: 10-20-2002, 08:20 AM
