Results 1 to 5 of 5
Thread: Cold weather hurt it at all??
    Cue
    Cue is offline
    Jun 2000
    Post Cold weather hurt it at all??
    Ive been putting off installing my system untill the winter is over, It is not going to be removeable and I was wondering if anyone has ad any problems with the cold weather and LCD screens or the computer components failing?
    Dec 2000
    Oneonta, NY US
    Post
    Before anybody yells at you:
    There are lots of posts about the cold weather issue just hot search and your off.
    The general opinion is that it doesn't hurt. There are however a few things you can do for very cold weather as well very hot weather.
    Search the posts and you'll see.
    -Chris
    chris@rollinpc.com
    -Chris
    chris@rollinpc.com
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    I have to say I left my system in the trunk of an 85 honda accord, and when I took it out to put in the new civic ( about a month ) The 90 or higher degree heat had toasted my brand new soundblaster live mp3 edition.
    I found a solution, but its winter now. I got a new card, and am waiting for summer to see if I need the solution, this company (I will see if i can find the name and web page), but they make 12 vold AC systems, this is no fan, its a complete miniature AC system. they quoted me 200.00 for a base unit.
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Post
    gizmomkr: I highly doubt that 90 degree weather toasted your SB card. The inside of the computer gets much hotter then that under normal use. I have seen machines run without a power supply fan for weeks and come out with no damage. I would assume that your card was defective from the start and the lower then normal heat had very little to do with it's failure.
    The generan consensus on temperature: If it is cold enough or hot enough to effect the PC, then you wouldn't be living there.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Dec 2000
    Smyrna, Ga, USA
    Post
    I cant say I agree -
    I used the system alot in the old car, and it worked fine, I shut it off one day, and bought a new car. I changed *nothing* in the system originaly when moving it from car to car, and the only thing that was wrong was the sound card failed . I tried everything, spent an hour on the phone with creative labs, they said the card was toast.
    Yes a system could run at 90 or higher, but its going to last longer has have less problems runing at 70. Have you ever been in a data center -they keep them at 70 for a reason.
    [This message has been edited by gizmomkr (edited 01-10-2001).]
    Gizmo-
  1. Replies: 7
    Last Post: 01-17-2004, 05:35 AM
  2. cold weather
    By blaster in forum General Hardware Discussion
    Last Post: 12-11-2003, 06:12 PM
  3. carputers and cold weather?!
    By mrzigzag in forum General Hardware Discussion
    Last Post: 08-06-2003, 02:00 AM
  4. Hard Drive screwed in cold weather!?!!?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-23-2000, 12:41 PM
  5. Hard Drives in cold weather?
    By nicksmurf in forum General Hardware Discussion
    Last Post: 11-17-2000, 11:44 AM
