Results 1 to 6 of 6
Thread: pc won't boot up
    May 2007
    pc won't boot up
    Guys i need some help. Just recently got my carputer up and running and now it has a fault.
    The message is saying it has missing or corrupt files.
    windows\system32\config\system. It suggests using a set up cd with windows xp pro and fixing it that way. Great idea but i don't have a cd as this pc came installed like this with no backup disc.
    Any ideas welcome
    Aug 2006
    Tried booting it in safe mode?
    May 2007
    How do you do that?
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    its usualy F8 while the computer is booting up
    if the computer came with XP pre installed, it more than likely has another partition with the restore already on it just waiting to be used. most companies are getting away from sending out disks with their systems...
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
    Mar 2007
    Surrey, BC
    go to any local computer store and ask for a windows xp pro oem cd. they'll give ya a copy (but no license) for usually just the cost of the cd.
    run the cd and try running recovery console ... if you cant access your system via safe mode.
    if you'd like more info, a good place to search for a solution would be at and search that error message you're getting. you'll find detailed instructions on how to solve your problem.
    May 2007
    Thanks guys, i guess i will need to plug in a keyboard then since i have no control with the touch screen while it's trying to load up.
  1. How2 control CarPC from key fob....
    By NotchbackVW in forum Power Supplies
    Last Post: 09-21-2007, 06:27 PM
  2. Touch screen causing PC to not boot?
    By chewEboy in forum Power Supplies
    Last Post: 05-31-2006, 03:58 PM
  3. Replies: 6
    Last Post: 04-09-2006, 03:23 PM
  4. Replies: 6
    Last Post: 04-07-2005, 10:15 AM
