Results 1 to 10 of 17
Thread: GlobalSat BU-355 COM port problem
    Newbie RichIbizaSport's Avatar
    May 2007
    Hull, UK
    Hi guys. Ive just bought the above and i cant seem to get it to work. I have a VIA EPIA ML6000EA with a serial port (rs-232, 9 pin d-sub, male). The GPS unit i have bought has a female ps/2 port. Ive connected these using a ps/2 to rs-232. It doesnt work at all, no led's light, it doesnt show on my com port in device manager and the program supplied on cd scans the COM ports and finds "NO DEVICE".
    What am i doing wrong?
    Will i have to buy a ps/2 to usb converter? as the cd has the usb drivers
    thanks
    Rich
    May 2007
    Hull, UK
    Aug 2006
    The reason no LEDs lit up is because, when using a serial port for your GPS receiver, there is usually a cable that splits to a ps/2 and a serial port. The receiver connects to the PC through the serial port and receives power through the ps/2 port.
    Thus, your PC is not recognizing the receiver because it has no power. You'll need either what I mentioned above or, like you said, a ps/2 to usb converter since it can connect and draw power through the usb port.
    Strange that your receiver didn't come with the proper connector, though...
    May 2007
    Hull, UK
    well, after spending an hour with a soldering iron and a multimeter i failed to get it to work.
    i was following this diagram:
    http://www.usglobalsat.com/images/BR...232_pinout.jpg
    Ive connected everything correctly i think. its just i dont know what to do on the rs232 end of the cable. does the serial port only need information from two pins (2 and 3)? what is the need in the rest of the pins? e.g. 1,4,5,6,7,8,9
    Aug 2006
    Make sure all the cables are connected to the corresponding port on either end using the following links as guides to the pinout diagrams.
    PS/2 -> Serial (9 pin)
    and http://pinouts.ru/InputCables/MouseP...l_pinout.shtml
    May 2007
    Hull, UK
    http://www.hardwarebook.info/Serial_%28PC_9%29
    from there ive connected pins 2 and 3 to the correct pins on the gps mouse, 4 and 5. Ive then connected pins 1 and 2 of the min-din end to +5v and ground. What else do i need to do?
    Aug 2006
    The serial port needs a connection to ground at pin 5.
    Also, check out the last link, the last row in the table on the page.
    May 2007
    Hull, UK
    Would anyone be kind enough to tell me what pins of the rs232 goto which pins of the ps/2 port
    RS232
    1 CD
    2 RXD
    3 TXD
    4 DTR
    5 GND
    6 DSR
    7 RTS
    8 CTS
    9 RI
    PS/2
    1 = +5V (from floppy)
    2 = GROUND
    3 = ?????
    4 = RECEIVE (PIN 2 of rs232)
    5 = TRANSMIT (PIN 3 of rs232)
    6 = ?????
    What do i do?!
    thanks guys
    May 2007
    Hull, UK
    bump
    May 2007
    Hull, UK
    bump again. My entire project is on the hold until this is sorted
  1. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  2. COM Port problem help
    By Cypher333 in forum LCD/Display
    Last Post: 10-06-2004, 07:42 AM
  3. parallel port LCD problem
    By jethari in forum LCD/Display
    Last Post: 09-05-2004, 10:56 PM
  4. Tv in and out at the same time problem...
    By cyrocr in forum General Hardware Discussion
    Last Post: 04-04-2003, 04:40 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
