Don't think it's possible in the Voom case, simply because of the size.
i have the blue (original) zoomPC automotive case...
has any one been able to fit in an internal PCI video card ? possibly using a pci riser of some sort ? so i dont have to use VIA's ****ty buggy software...
i imagine it is possible .. just curious if any one has done it and if so what did u use etc ..
I've tried - even with a flexi riser... just a few mm off each time.
Terran
Just to echo the above posts, I know quite a few people have asked about it before, all with the same result...not enough room.
Jan Bennett
indeed i tried searching but then i relised its called a VOOMPC case lol
any way .. ive decided to order a pack-box a4 which allows me to use 2 PCI cardswhich is much better
and a VIA PCI riser card
there is a way to install a PCI card to a voompc case , using a flexi PCI and mounting the PCI card in a external enclosure outside .. but to much hassle lol.
all this because rubish VIA couldnt embed a half decent graphics card on there mini-itx bords
Then it's not mounting a PCI card IN a VOOMPC case....It's mounting it OUTSIDE a VOOMPC case.
Jan Bennett
ah but u have to mount the PCI PCB board inside the MB slot :P
thats the only way u can do it anyway , but ive decided to get a new case
