Results 1 to 6 of 6
Thread: Fiberglass resin questions
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Okay... this las batch of resin has been curing for about 36 hours now and is still not completley cured. I suppose I somehowdidn't add enough hardner (probably high from the last few layers). Anyways, does anyone have any tips for drying it? A heat gus doesn't seem to be doing too much... but then again it's outside in Houston, TX where the humidity is about 99.9%. Think I could stick it in the oven on low?
    I'm not kidding here. My girlfriend might kill me... but hey, life goes on ;-)
    *** EDIT ***
    I guess that last statement didn't make any sense... I might be dead but life will go on...uhh... I need to quit sniffing the resin.
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Yeah, that stuff will mess up your head... get some air.
    Put another layer over it, and this time add a little extra hardener. Mine dried in less than 2 hours.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    heh... good to see another Houstonian... err... Houstonite.. .whatever.
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    Re: Fiberglass resin questions
    Has the hardener been in the storage for a while? If it has, it probably lost its concentration. You can clean the wet layer of resin with acetone. Then start with a layer of resin with new hardener.
    *** EDIT ***
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    you could try painting some hardener over the top. the other option is to mix up some more resin and hardener and give it another coat
    Aug 2002
    here is the best quasi-faq on glassing I know of.
    http://www.termpro.com/cgi-bin/ubb/u...;f=32;t=000549
    as to your question, its prolly irrelevant now but:
    Q28.) Using heat gun? Downfalls?
    A: Too much heat applied to just the surface creates an uneven cure and increases the surface tension, cracking can be a problem, as well as unexpected suprise shrinkage during application of additional layers.
