Results 1 to 10 of 19
Thread: Project update... ;)
    Aug 2007
    Well..i'm in the middle of it now. Just feel like ranting for a bit !!!
    I've ordered the Xenarc 700IDT today
    Tomorrow the Macpac power supply and cables arrives.
    Today i ordered an auxiliary output for my pioneer deck.
    I'm gonna start to put half of my deck back together again now, as I relocate my pioneer deck to the lower part of my dash (98 civic). This will leave me with a free one din space on the upper part of my dash for the xenarc. Hopefully by Friday i'll be putting most of the components back together again, and by this time next week, i'll be surfing the net in my car
    Aug 2007
    Macpac cable and carnetix power supply just arrived one day ahead of schedule!!! HOORAY!!! Now, all I need is the screen and the mac
    Jun 2007
    Cincinnati
    I have a 99 civic I had a hard time figuring out where to put everything. My dash is a little different I actully have a double din space where my HU is. Also I have a compartment where your putting your HU thats where I put my mac. I'm curious where you put your mac if your putting your screen above your climate control and the HU in your lower dash in the console. Good luck and here is the link to my install. http://www.mp3car.com/vbulletin/show...-10-4-lcd.html
    As you sow, so shall you reep
    My Install- http://www.mp3car.com/vbulletin/show...-10-4-lcd.html
    Aug 2007
    AJWHATu
    Hey there, thanks for the link. Quick question though...or maybe a long one... how did you 'connect' everything together? Meaning: I know the mini just plugs into the carnextix device via the macpac cable..simple enough..but from the there how did you connect the carnetix to your car? Are the instructions simple enough? What did you do with regards to jumper settings? Also, are you using a powered USB hub? How did that get connected in? Did you have to make any adjustments to your fuse panel?
    As for my mini, I haven't 'found' a spot for it yet. Maybe cut my dash and install where the power outlet is...otherwise it's going in my glove box
    Jun 2007
    Cincinnati
    Quote Originally Posted by hondamac View Post
    AJWHATu
    I ran a wire straight from the battery and a line from the ignition wire to the ignition its Black and yellow. read the directions I read them about ten times for the carnetix. The jumpers at first were a little tricky but by the tenth time reading the directions It was clear as day. I don't remember all my jumper settings but If you have specific questions about jumpers I'll be glad to help. I am not using a powered usb hub. no adjustments to fuse panel.
    Also you'll notice when you get it that the wires are backward on the carnetix meaning your yellow is acc and red is battery. Also putting the mac mini in your glove box will be harder than you think. I put mine in my glove box to see if it would fit. It did but barely. The problem you will run in to is running your wires to the back of the mini the is a metal brace behind the glove box where the wires would come in. also directly behind the brace is your heater. the only other place I could think of to mount it was under the driver seat on some stilts incase of any spills. Goodluck man if you need any help just ask.
    Aug 2007
    Hmmm....I haven't picked up the mini yet. The glove box would have been a good choice as I wouldn't need to construct a dock. Do you have a lot of play on your wires when you pull the unit out? I didn't get any instructions with my carnetix, but I imagine you are referring to the ones online?
    Online, I see two installs for the mac. Regular instal and another that includes a P5V. I don't know what that is. Also, was your monitor also connected to the P1900/2140? If so, how? For me this is most difficult part..the wiring. One more thing, where did you install your carnetix?
    http://www.carnetix.com/installation...anual_V1_2.pdf
    Look at Pg. 15 of the manual. Is that the wiring I should be following? Any idea what that green Y cable is for? Where it connects to the mini?
    Jun 2007
    Cincinnati
    I don't know what you mean by this question "Do you have a lot of play on your wires when you pull the unit out" Are you talking about the wires connected to the back of the mac or the wires that plug in to the carnetix. I am referring to the instructions online.
    I believe the p5v is for an third 5volt power source it used for a USB HUB. Its an extra 25 dollars I think. Yes my screen is connected to the p1900 through the secondary power supply. Acutullay you can see my carntix kinda in my second picture downits behind the cig lighter panel look in the little crack you can see it. It just sits on top of the compartment(mac is in) with doubled sided tape. The green wire is for the power button on the mac. You connect it so your mini powers on when you turn on the car. Also I forgot to say in the first post Put inline fuse in your power wires.
    Aug 2007
    All good tips. What I meant was, when you pull the mac mini out of the din space, how much space did you leave so you can disconect the wires? I assume you did not build a docking station.
    As for the inline fuse... you mean, wire - to fuse - back to wire again to battery correct?
    No need to visit the fuse panel correct? I'll take a look at my local radio shack or automotive shop nearby and see what they can suggest
    Thanks for the info
    Jun 2007
    Cincinnati
    Thanks for the info
    I did not build a docking station I can just pull it out and undo the wires if I need to. Yes in line fuse is wire to fuse back to wire I had a hard time finding these so I went to a auto parts store and found a cheap little fuse block with about five fuses on it I broken in to single fuses and covered the metal with Electrical tape. Yes no need to visit the fuse panel unless you don't want to splice into existing factory wires. Radio shack might have inline fuses the one by me didn't.
    Aug 2007
    AJ,
    Did you connect the Y cable green/black to the mac mini power button? Do you disconnect that cable each time you pull it out? I wanted to build a docking station for it...but now that I noticed this cable, i'm not sure how that can be possible. Does your system auto turn on when you start the car?
  1. Centrafuse 1.14 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-01-2007, 10:34 AM
  2. FS: Lilliput 8" LCD w/ 2 Project Housings
    By migel628 in forum Classified Archive
    Last Post: 09-14-2005, 06:40 PM
  3. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 05:46 PM
  4. My Project - All help / advice requested
    By DST in forum General Hardware Discussion
    Last Post: 06-28-2005, 11:59 AM
  5. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 05:43 AM
