Results 1 to 10 of 17
Thread: I think I killed my keyless entry, 2005 civic
    Feb 2007
    Maryland
    For my project, I have to move my radio, and the first start was extending the radio cable. I broke the cardinal rule and sumply cut the connector off to add an extension to the line.
    Well...I forgot to disconnect the power, so the battery line was hot when I cut. When I did so, my digital gauge light up. Thats when I realized that I'm a moron. Well I continued to add the extention in and upon completion, many things stopped working:
    Keyless Entry
    Door locks when car if OFF but works when on
    The "you left the headlights on" screech
    and my digital mile counter resets every time I turn on the car.
    I assume that I shorted something out, and that I'm royally screwed.
    Anybody got any alternative ideas or know what the problem could be?
    CarPC status:
    [XXXXXXXXXX] 100% Complete
    [XXXXXXXXXX] 100% Installed
    [XXXXXXXXXX] 100% Software
    CarPC v1.2 is now in effect. Software updates and hardware additions to come.
    Variable Bitrate dhantiflag's Avatar
    Nov 2006
    Mentor, OHIO
    check fuses...
    im sure it is just a blown fuse someplace...
    check them all.
    Feb 2007
    Maryland
    fuses
    Good suggestion. I checked the ones that would seem to be involved:
    Radio/accessory
    Door Locks
    and a few others. I'll check the rest, but I don't think that's it (unfortunately)
    CarPC status:
    dont forget to check the relays, which should be located near the fuses.
    Also try resetting the ECU??
    Feb 2007
    Maryland
    The relays and the ECU are mainly related to the fuel injection system, so I dont think thats it.
    Everything worked fine before I cut those wires. Does anybody know what the radio is connected to? (other than the speakers, duh) There are 13 wires on the connector. 8 are speakers, 1 ground, 1 ignition, and at least 1 power. That leaves 2 lines that go to something.
    CarPC status:
    ECU's these days control quite alot of things these days! The digital mile counter is one of those things which most likely the ECU controls.
    I am a n00b too when it comes to these things, I just pointed out everything I could think of, hopefully so someone else would take over, or maybe you might find it helpful and might make you remember something.
    May 2006
    Calgary, Alberta
    Reset the ECU. Instructions should be in your manual.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Feb 2007
    Maryland
    Oh ok! I just read a little and it said it was for fuel injection. I'll reset it and see what it does! I hope that's all. I'll check the relays, but How do I know if they're bad or not?
    CarPC status:
    Low Bitrate 95rodeo's Avatar
    Oct 2006
    Auburn ca
    i know you said you checked the fuses. but did you check all of them? your car should have an underhood fuse box in addition to the one inside oftentimes a fuse will control several seemingly unrelated things. like on older hondas the constant for the radio, the domelight, and the clock will be on one circuit. so i guess all im saying is check them all. use a meter set to test continuity and probe the contacts on the back side of each fuse. sometimes a fuse that looks good will in fact be blown. good luck
    Mar 2006
    Colorado, but Canadian!
    Ok, we both have 7th gens.
    The stock radio has a fuse on the back. Check that first. It may have an internal fuse too I dont know. Then the fuse box under the steering wheel column on the right (if looking out windshield). Then the fuse box under the hood. The one under the hood does have a fuse for something that has to do with the radio.
    I say leave the ECU alone. Something like this should not require an ECU reset.
    Also I am not sure as I replaced the factory keyless entry immediately, but I think that is actually controlled through the radio. Meaning if it has no power for a certain time, its internal backup dies and you will have to "relearn" or "reprogram" the key to work with that car. Honda stealerships charge $90 just for the programming.
    1.9in x 2.9in -- 47mm x 73mm
  1. honda civic 2005
    By jbelle7435 in forum Newbie
    Last Post: 11-25-2006, 06:27 PM
  2. Mustang keyless entry unit
    By jdogg1583 in forum Input Devices
    Last Post: 04-09-2006, 11:32 PM
  3. Where to DL old version of RR?
    By accentsound in forum Road Runner
    Last Post: 07-12-2005, 12:51 AM
  4. looking for keyless entry system
    By yonu in forum Classified Archive
    Last Post: 05-21-2005, 11:00 PM
  5. Keyless Entry Shutdown Controller
    By Sinorm in forum Power Supplies
    Last Post: 04-07-2004, 08:30 PM
