You have to isolate the problem. Can you plug a laptop directly into the screen with a shorter cable? See if the problem persists. If the problem goes away, it's the 15' VGA cable (some kind of interference -- or just a poor cable). The problem remains, then it's interference on the monitor itself, perhaps from the power source. Can you try plugging it into the regulated power of your power supply?
Have a buddy with another screen you could try?
Anyway, you get the idea. Keep trying swapping out individual pieces of the setup (only one piece at a time) until the problem goes away... then you've isolated the culprit and can proceed with correcting the problem from there (post another thread if need-be once you've isolated it).
LinkBack URL
About LinkBacks
