Results 1 to 8 of 8
Thread: Digital audio out quality help
    Oct 2007
    How do I get the absolute most pure 2 channel digital audio out of my PC?
    I am using an external D/A converter that will accept either coax or optical in and will give me a balanced signal that I can run to my balanced volume control.
    I am concerned about my OS (98lite) volume control as well as other software degrading the quality of the signal.
    So far the hardware I have is a Jetway 7f2we1g5d-oc-pb mother board
    Soundblaster live USB and a Panasonic UJ-85J-B Slim Slot load cd rom.
    Will this cd rom hinder performance?
    Are there issues with getting digital audio from a USB device?
    Keep in mind that I am looking for the absolute best no compromise performance
    Oct 2007
    Any help here would be great. I know that someone here has some answers.
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    Search for ASIO and ASIO4all. As for volume control, unless you don't mind losing bits of resolution, you need to use a volume control after the DAC.
    Apr 2007
    x2, people who use Winamp for ASIO use its volume control and are happy with the results, so you can try it out and see also.
    Oct 2007
    Thank you very much
    Thank you very much that was the type of info that I was looking for. I have decided to use an analog volume control after the D/A. My next concern that I am having trouble finding information about is the physical path between my cd rom and the D/A. Will using a USB adapter to connect my cd rom to the IDE port allow for bit perfect transmition?
    mst
    mst is offline
    Constant Bitrate mst's Avatar
    Nov 2003
    France
    _
    Mar 2004
    Little Elm, Texas
    There are a number of threads on here as well about this.
    What you're wanting is commonly referred to as 'bit-perfect'.
    http://www.mp3car.com/vbulletin/advf...ew&advfaqid=25
    WinAmp and ASIO is a way to achieve this as well.
    I would be less concerned with yoru CD rom hindering sound and more concerned about your sound card hindering sound.
    You will need a sound card that is capable of NOT resampling the audio stream.
    I don't believe the Sound Blaster Live products are capable of this, however the Audigy cards are (through a tick box on a tab which says 'enable bit-accurate playback').
    Jan Bennett
    Oct 2007
    Wow! thanks guys for all of the help! I did not expect this quality of info. I think I just found my new favorite place on the web.
  1. SDPIF digital Coax into car audio pieces
    By RedGTiVR6 in forum Car Audio
    Last Post: 10-14-2008, 01:06 AM
  2. Replies: 24
    Last Post: 02-19-2008, 02:03 AM
  3. SD crashes on startup
    By mangus580 in forum StreetDeck
    Last Post: 10-05-2007, 12:14 PM
  4. Quality of Intel MacMini audio
    By SigENeaT in forum MacCar
    Last Post: 01-11-2007, 05:12 PM
