Results 1 to 10 of 16
Thread: Strange Issue Booting Windows - Need Help Please.
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    I have an Asus K8V-VM motherboard and I'm using a SATA HDD.
    I am having an issue on the first cold boot of each use.. I turn the carputer on and then after about 15 seconds I get:
    "Error Insert Boot Media in selected Boot device and press a key"
    All I do is hit CTRL+ALT+DEL, it resets and it then boots right into Windows.. Makes NO sense what so ever.. I can then do system restarts with no problem but if I do a shutdown or a hibernate and try to turn it back on it does the same thing.. It tells me the above error, I manually reset and it goes right into Windows..
    Any ideas on this?
    Thanks much.
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Elsewhere
    Id' check in your BIOS to see if you have USB Boot enabled.
    You might also make certain that your SATA HDD is the first item listed in the boot order.
    How about the Wiki?
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    It's probably something to do with the drive not spinning up fast enough to have its boot area accessed in time - you might have to try and lengthen your POST times (make it do a long memory check, turn on all your onboard devices etc) and see if that helps.
    Oct 2003
    Poland, OH
    Quote Originally Posted by Grrrmachine View Post
    This could very well be it because when it does boot it's in Windows in what seems like seconds. POST FLIES right by so I think you may have something.
    @ DP, yes.. It's the first (and only) device listed in boot order.
    Thanks fellas!
    Oct 2003
    Poland, OH
    I am still having this problem. I turned off Quick boot in the bios and I still have to hit CTRL+ALT+DEL upon the first boot 80% of the time..
    Variable Bitrate Splash-X's Avatar
    Mar 2006
    Palm Harbor, FL
    Double check the SATA and Power connections on the board and the drive. You may need to hot-glue the plugs in place.
    There is also a chance that your drive may be defective and doesn't spin up properly.
    Oct 2003
    Poland, OH
    Quote Originally Posted by Splash-X View Post
    I'll double check those this weekend.. However, if the drive was defective.. Wouldn't it show some signs other than this?? I mean it works perfectly fine after the reboot..
    Also, I had this exact system working fine in a bench envinroment.. My motherboard's USB ports died so I then got a new one and that is when this started.. The POST on my new motherboard is the fastest I've ever seen even with all the options for "quick boot" turned off.
    Oct 2007
    What was the ambient air temperature when you had this issue? Hard drives and PCs in general don't like being really cold at first boot.
    If you are in Poland shoot me a PM as I work in Boardman. I do IT work for a living.
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    [QUOTE=longhair;1141723]What was the ambient air temperature when you had this issue? Hard drives and PCs in general don't like being really cold at first boot.
    If you are in Poland shoot me a PM as I work in Boardman. I do IT work for a living.[/QUOTE
    Funny, Mine does the same thing except its on my test pc. (notebook) Mine happens about 90% of the time and i either 3 key or hard off and windows fire right up. SO i dont think it is the ambient temp Longhair. However it may be a spinup issue as mentioned by Splash-X as mine didnt start happening until i replaced my original hd.
    If you cant DODGE em, RAM em.
    Oct 2003
    Poland, OH
    Yea, I don't think it has anything to do with temperature.. I'm going to swap the HDD's and see if that fixes it because I changed all options I could in the BIOS and still every time I have to restart upon cold boot.
  1. Replies: 2
    Last Post: 04-06-2006, 11:07 AM
  2. Strange Xenarc Calibration Issue
    By blurp in forum LCD/Display
    Last Post: 06-06-2005, 03:55 PM
  3. dual booting linux and windows on carpc
    By kilomo in forum Newbie
    Last Post: 02-26-2005, 03:16 AM
  4. Strange Xenarc Problem - Windows Related
    By tbird2340 in forum LCD/Display
    Last Post: 02-06-2005, 08:18 PM
  5. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
