Results 1 to 10 of 16
Thread: program stopping shutdown
    Oct 2007
    orlando fl
    hi,
    I have a program running on the computer that when you goto shutdown , it pops up a box asking if you want to stop the program . this causes the shutdown to hang and needs user input to select yes. is there a program or some way for force this to close thus doing a proper shutdown without issues?
    Constant Bitrate Grimoire's Avatar
    May 2006
    Fayetteville, NC
    Quote Originally Posted by Collegeboyslive
    Which program is this that your using to control/shutdown the computer? A front end you got from here? Windows? Mac? Linux? Shell? Friggin Magick?
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    I believe tweakui can manipulate this for you. I recall an option about forcing shutdown. I haven't used it in a while, so I don't have anything to back this up. Good luck.
    Oct 2007
    orlando fl
    lol sorry , using windows and the shutdown is initiated with an opus psu pulsing the power switch on the atx mother board.
    i have to use shutdown right now caus efor some reason hybernate and standby dont recover proprly
    Oct 2007
    orlando fl
    nope i looked i cant see anything in there about forcing a shut down
    Jun 2005
    Oakland, CA
    Well, I was pretty sure it was in there. Anyways, all it does is modify the registry. A quick google search for that registry key pulls up this page. Check out the section about 1/3 the way down called "Force Program Exit".
    http://kellys-korner-xp.com/win_xp_restart.htm
    Oct 2007
    orlando fl
    nope still didnt help , I am useing windows media encoder and that is the program that is stopping the shutdown, it pops up a box askng if i want to stop encoding and you have to click yes. nothing i can seem to do will get windows to get past it to shut down.
    i cant use hybernate because when it comes back from hybernate the windows encoder program turns off for some reason.
    very frustrating
    Jun 2005
    Oakland, CA
    Oooooooh!!! I was thinking it was the dialog box of 'program is not responding, do you want to shut it down'. Hmm, maybe something with a scripter like AutoIt might work.
    Oct 2007
    orlando fl
    problem is the computer will have probably already shut the autoIt program down as it started the shutdown sequence. i will try it though
    Jun 2005
    Oakland, CA
    From "Run" or a command prompt, type "gpedit.msc". This pops up the Group Policy editor. Find "Computer Configuration" > "Windows Settings" > "Scripts (Startup/Shutdown)". Open the Shutdown one and add a script from AutoIt or similar with a simple "ProcessClose" and the name of that program. Would that do the trick?
  1. FAQ: Do-It-Yourself Startup/Shutdown Controllers
    By Bugbyte in forum The FAQ Emporium
    Last Post: 11-04-2010, 09:48 PM
  2. Shutdown question
    By EricE in forum Newbie
    Last Post: 02-17-2006, 10:08 PM
  3. Replies: 2
    Last Post: 12-05-2004, 02:51 AM
  4. Replies: 3
    Last Post: 11-14-2003, 08:47 AM
  5. How do i start a program when windows starts its shutdown rutines
    By darkwingduck in forum General Hardware Discussion
    Last Post: 12-10-1999, 07:28 AM
