Results 1 to 7 of 7
Thread: Head Unit Face Plate Hack
    Feb 2002
    Ontario, Canada
    - An idea to have Backlit profesional looking buttons - Okay has anyone taken an old stereo and ripped off the face plate that has all the buttons on it and mapped the circuit board or buttons to a keyboard hacked controller board? I'm planning on doing this in the next 2 weeks since i need at least 9 buttons to control my MP3 player. I've actually got a 94 VW stock stereo that was dead so i ripped off the face plate and plan to use this. It has 12 buttons in total so i can assign 1-6 as playlists, MIX will be shuffle, > will be seek.... you get the idea. Has anyone done this yet ? I know i might have to ditch the circuit board and build a new one but i can't see it being that big a deal.
    May 2002
    Sef'Kylar
    I think you should be able to accomplish your goals with minimal aggravation.
    I have a few ideas on backlighting buttons, but since i'm switching to touch screen it's become less important
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    Go to this site, you might get an idea on using LEDs to light up stuff.
    http://metku.net/index.html
    Feb 2002
    Ontario, Canada
    okay, after workin on this for a couple of weeks now i've finally finished my new install of a custom button setup. I used an old VW radio, took it apart and connected a keyboard controller circuit board to all the buttons. The face plate buttons are backlit green to mach my Palm and Kenwood deck ( dual illumination ). The Palm sit's in a cut down cradle that has 5 magnets at the back and the Palm has a metal strip adheared to the battery cover so the palm is easy to remove but stays solid when driving around. The button layout is as follows:
    SCAN=Shutdown, MODE=Hold mode button in conjunction with #'s 1-6 for 6 more Playlist Dir's for a total of 12. , REP=Reboot winamp, MIX=toggles shuffle, NUMBERS 1-6=Playlist Dir's, >=Seek forward, <=Seek backward, STOP=Stop etc.....
    The buttons activate keypresses that activate Macros that i made up with Macro Magic, Example: Turn on computer and music starts playing......Push #1 button then music stops, then plays a wav file "Alternative music ...Now loading", then loads the Alternative Dir, Then pauses 10sec's , then sorts alphabetically by path and filename. The same goes with all the playlist buttons, you get a computerized female voice introducing the genre your about to play.
    I do a lot of driving at night so backlit buttons were a must feature on my list, and as for the Vocal intro for the playlists..it just help's me remember what button is assigned to what playlist.
    Variable Bitrate spyhunter's Avatar
    Jul 2002
    central jersey
    most impressive.
    Alex
    90 300zx twinturbo conversion
    Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
    Dec 2001
    Columbia, Maryland
    what software are you running on the palm?
    Feb 2002
    Ontario, Canada
    PalmMMC is running in the pic, but you need the .dll file from PalmAmp to put in your plugin folder of WinAmp for it to run.
