Why are you worried about condensation? Condensation occurs on stuff that's colder than the ambient temperature, and the carpc should be quite a bit warmer
my old setup has no problem with winter weather, the new setup however, is more expensive but much less effective for winter. Hard drive fails, and xenarc fails too.
Blowing warm air over a cold surface will cause condensation on the cold surface.
This would be my only concern.
I'm working on a suplimental warming scheme for my trunk mounted system as well. Haven' worked out the details yet but I'm getting close.......
I'll post something if I ever get close to a final stage.
Leonardo Da Vinci
Also note that mp3car store has an automotive grade hard drive that has temperature specs down to -30F. Here's one, there are at least two listed in the store.
Want to:
TruckinMP3
Read the FAQ!
My 300 gig Maxtor drive has trouble turning when sitting in an ambient temperature of < 30F. It takes about ten minutes for XP to finally load if the drive sits overnight in below-freezing temperatures. Fortunately, I have the drive in a caddy that I can easily remove and bring in the house overnight. Using a caddy also makes it very easy to update music, videos, pictures, etc., since I can just plug it into an empty bay in my house computer. I'm aware that a caddy won't work for everyone due to the nature of their setups, but it works well for me.
I'm starting to have some problems with extremely cold mornings. My carputer wont boot untill I get the car all warmed up. I found these drives after a bit of searching. They are supposed to be good for cold weather.
Hitachi Travelstar model: IC25N040ATCS04-0
Toshiba MK3029GAC
MK3029GACE
MK4036GAC
MK4036GACE
MK4050GAC/MK4050GACE
Seagate ST940814AM
ST930817AM
ST930818AM
ST940817AM
ST940818AM
ST960817AM
ST960818AM
ST980817AM
ST980818AM
fujitsu
MHW2040AC
MHW2060AC
MHW2040AC e
MHW2060AC e
Seagate EE series notebook hard drives are good for -30C.
