Just wire in a momentary pushbutton to the power switch terminals on your motherboard. You can probably steal one from a old computer case you are not using. If you want to be able to turn the computer on without your key in the ignition, you would also need to set up your power supply to be always on, which should just involve wiring the ignition +12V input to a constant on +12V source.
LinkBack URL
About LinkBacks
