Congrats on the first. nice work bench. You should try to get a DC-DC ATX PSU and dump the inverter, AC PSU, and ground loop iso. You'll end up with A LOT smaller setup than what you already have. Try to locate a VGA monitor instead of using composit in monitor. The quality is way better than composit. cut off the second IDE header and keep the shortest cable you need.
LinkBack URL
About LinkBacks
and because I have 300W available. More then 150W doesn't exists in DC-DC converters or is very expensive. Don't you thing a VGA is a little bit too big?
The page just needs flash and javascript...I don't know why it doesn't work with your internet explorer or netscape. Maybe you should consider upgrading to IE6.0
