Results 1 to 10 of 14
Thread: LPG and mp3 pc
    Jan 2002
    Melbourne Australia
    LPG and mp3 pc
    Hey people my mp3 pc maybe coming back up outa the dead I just wanna ask any of you guys if you have ran a computer in your boot and had a gas (lpg) tank in there too. I am just a bit worried that like if the gas leaks and the computer goes to start up there could be big problems
    http://austmp3car.tk
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Hi,
    Here in the netherlands, theyīre using a lot of lpg cars..
    If gas would leak.. (and thatīs NOT GOOD).. the computer wonīt make much difference.... If there would be gas filling up in your boot.. just a bit friction will ignite it, so I donīt think the computer will put on some extra risk..
    I donīt know your car, but there might be enough space left under one of the front seats.. you might fit the carputer there..
    Greetz,
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Jan 2002
    Melbourne Australia
    Hey thanks for the extra info man. The front seats would be lucky if they have 4cm of height under them so i think mounting it under the seat is outa the question. Wouldnt it take a less amount of gas leaking for the say fan or other elictrical parts on the computer to make it egnite up. Than comparing it to a amp in your boot etc etc.
    Jan 2001
    The Netherlands
    Hi !,
    I donīt think I can answer that question for you, simply because I donīt know that much about lpg, and the point/energy it needs to ignite....
    but....
    In general,
    I think it would be safe to say.. "When you are allowed to run an amp near the gas tank, a computer is also allowed..."
    Your car / LPG-installation didnīt come with some warning about the lpg-tank in your car.. like.. "Donīt ever put an amp or other electrical equipment close to the tank... "
    your lights.. braking lights and such are also located in the back off the car.. when a bulb breakes, you prob. have to replace it from within the thrunk... this is also some kind off electrical equipment, and it doesnīt affect the gas-tank..
    Really.. if a gas tank leaks.. itīs faulty and should be replaced.. a gas tank should leak ZERO...
    Think off it.. they can absorb quite some energy without breaking or something.. .. otherwise it wouldnīt be safe to put one in the thrunk... what if someone rear-ended you really hard.. The tanks are designed to handle this, and donīt explode immediately.. (.ok.. when fire starts out.. heating the gas inside the tanks.. then it MIGHT blow... )
    Hope this helps you out..
    Greetz..
    BTW.. you could get an all-in-one mobo and put that under the seat !
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    how about mounting under the rear seat? I don't know how much room there is under there, but my old XD Falcon had a fair bit of room under the back seats. Just a thought.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Just a thought...
    Here in the states they ask that you don't use cell phones while pumping gas because of the possibllity of the small electronics igniting the fumes from the gas...
    If you're talking about something else just disregard this post.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Jan 2001
    The Netherlands
    gas in this thread is Liquified Petroleum Gas which is just another oil-derivate..
    unlike petrol or diesel which are fluids at normal temperatures LPG is a gas at normal temperature.. Therefore it has to be stored in a High Pressure tank located in the back, or under your car. (you can see it like butane/propane gas-tank to īpowerī a BBQ or something)
    In order to make the lpg īusableī for a normal petrol engine.. the liquid lpg has to evaporate before the engine takes it in.. this is done by a special unit very close to the carburator/intake off the engine..
    In newer models (LPi) the lpg gets injected directly into the cylinder and it doenīt need the evaporation.... it will become gassy in the cylinder where the temperature is much higher than that of the stored lpg (-80C I believe)
    Personally (donīt take this as advice) I think that the warnings at gas-stations are only there, just in case something does actually blow up.... The owner of the gas-station can say "I warned people, so it isnīt my fault... " .... about the same as medicines... on every paper with them it says you CAN get headaches from the medicines... but thatīs (almost) only there in order to prevent people from suing the manufacturers.... just because the got a headache.. The manufacturer warned about the problem that a headache could be one off the side-effects, so it cannot be suied for that particular problem..
    Greetz,
    Apr 2002
    North Yorkshire, UK
    Like the wonderful warnings on peanut packets, saying: "Warning, product may contain nuts!"
    Or the other one, "After heating, contents may be hot"
    Dave
    Jan 2002
    Melbourne Australia
    Hmm thanks for the info guys. I might have to have a think about were im gonna mount the pc for now. Im just still worried about that much power in the boot beiging that close to LPG. (if u know what i mean)
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    That's actually an urban legend. While the cell phone is not rated to operate in an explosive environment, there is no way it can cause an explosion since there is nothing inside that can generate sparks (even the vibrator motor is brushless). It does not put out enough RF energy to induce a large enough current to cause sparks.
    I woudn't worry about putting a computer next to an LPG tank. If you have a leak, your computer will the the least of your concerns. And quite simply, it will not leak. Don't worry about it at all. It is singificantly more dangerous simply filling your car with petrol. Also, there is already power routed into your trunk (taillights, signals, trunk release, power antenna, etc). Don't worry about it, there's no reason to.
