Results 1 to 6 of 6
Thread: g35 style car remote start help
    Mar 2005
    i was wondering if there is a way to make a keyless remote system meaning like the new g35 you dont use a key to start the car nor use a key to open or unlock the car .i want to have a system that will when the remote is in range the car can be started by push button and if the remote in not in range car will disconnect and shut off does any one know how i can make a simular system or anything close?thanks alot
    Mar 2006
    Colorado, but Canadian!
    RFID. And it is not just the g35 that does this, nor were they the first.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    yea i know g35 wasnt the first i just used it as an example where most people know i know rfid but i cant seem how i can get it to work just like the car systems i just need a lil help to get started if any one has an idea please let me know
    Sep 2007
    how bout using a bluetooth module. i am sure that someone on here can write something so that when coupled with the fusion control center and your cellphone comes within range of the bluetooth module, one of the outputs of the fusion control center sends a negative pulse to a relay to unlock your doors.... just a though
    Sep 2007
    the previous idea would also work with a remote starter, provided that your remote start module has a 12v negative activation wire.
    Jun 2006
    Ventura County
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 10:44 PM
  2. carpc monitor vibrate at start car engine >???
    By Zo6om in forum LCD/Display
    Last Post: 02-10-2008, 04:37 PM
  3. car remote start using bluetooth
    By 3l33tPhantom in forum General Hardware Discussion
    Last Post: 07-11-2007, 11:23 PM
  4. Car Start on Finger-Print Recognition?
    By tyRion in forum Hardware Development
    Last Post: 01-23-2006, 07:05 PM
