Does anyone know if you can but dynamic range compressors for cars?
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
When the engine is running (I have a very noisy engine) I really have to turn the stereo up to hear some of the quiter parts of the tracks and then when the main track cuts in, I madly scramble for the volume control while my ear bleed.
Bands like Skunk Anansie are really bad for this kind huge range in volume levels.
Try doing a search for normalizer. (sp?)
Monger
ICQ-7207702
UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
i'm currently listening to minidisks in my car while i`m building my mp3player. I`ve recorded all of my minidisks with loads of dynamic compression (aswell as a bit of DFX enhancement), so i can hear the quiet bits.
I know it sounds like a bit of a bodge, but recording whatever media u use in the car (tape/cd/minidisk) with dynamic compression works fine. The only downside is that you can`t adjust the amount of compression after it`s recorded, but i usually find a nice setting and stick with it.
Rob, this may be a bit of a stretch, but its just an idea. The simple fact that you've installed a car 'puter, means you don't mind doing a little "rigging". Take a look at this unit:
Phonic Compressor
I bought one of these from Mars Music (who has since gone out of business) for $39.95. I'm not saying you'ld find one that cheap again, but you might get close.
Whats interesting about this unit is, even though its a 19 inch rack mount, its only 4 inches deep, and it runs on a 10 VAC-600ma wall-wart. It would be pretty simple to build a small supply for it, and you could take it out of its case to make it more compact. Then just "hard-wire" the controls that you would never use and keep what you would use.
Like I said, its a stretch, but do-able.
Dex.
