Results 1 to 10 of 14
Thread: Ideas for mounting CarPC in trunk
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi,
    I would like to clean up my Accord trunk... Specifically, I am looking for ideas on mounting my CarPC in there. I have tried for ideas, but so far I am coming up dry. Could I get some suggestions? (Pictures would be great)....
    My car is an Accord, but suggestion from any trunk install could lead to more creative thoughts flowing....
    Nasa
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Ive found that mounting the pc by screwing it to the back of the rear seats works well. Looks neat, and I can diagnose any problems from within the car (rather than having to pop the trunk) because my rear seats can flip down. Thats only if you have a fairly compact case though.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Hatch or sedan?
    Here's what I did in my 300:
    Hinged shelf.
    If you've got a hatchback, you can mount in on the sides, under panels, seatbacks (as mentioned) etc.
    You're really only limited by your imagination..................
    Cheers
    Leonardo Da Vinci
    Aug 2006
    PA
    GreatWhite,
    Sedan.
    BTW:
    "You're really only limited by your imagination.................."
    Given my imagination is on short supply, I have to borrow ideas from everyone else!!!
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by nasa View Post
    where is your current carPC mounted/installed?
    in my previous system/installation I had my laptop/docking station mounted to an MDF shelf that sat on the floor of the trunk (amplifier on the bottom 'shelf' with the laptop on the top 'shelf' above it).
    later on, to save space I hung a metal shelf from the rear deck (it wasn't actually a shelf, it was a steel cover from an old horizontal desktop PC case) from the rear deck. this saved alot of space but unfortunately it got so hot up there (when the car was sitting in the hot sun) that my laptop would overheat and shutdown. I left the 'shelf' there and now I use it as a general storage shelf
    neither solution was ideal, and I never really wanted it in the trunk but at the time money was tight so I didn't want to spend any money on a new system so I used what I already had. the laptop/DS was too big to fit anywhere else, so it had to go in the trunk.
    I just replaced my old laptop with a Intel mini-ITX system in a small aluminum case from Mo-Co-So. this case allows the motherboard tray to be installed normally or upside down in the case, which gives you a few different mounting options (including hanging it from the rear deck or mounting it to the side or seat-back).
    this was much smaller than the laptop/DS and could easily fit under the passenger seat. so that's where I installed it. now I don't have to deal with the heat issues in the trunk or the cable extensions / long wires. do you have any other mounting locations you are considering or are you only considering the trunk? (and if so, why?)
    Aug 2006
    PA
    FusionFanatic,
    My carputer is located in my trunk. It's mounted on a mdf board (with 2 rails, so I can remove the computer as necessary) which is screwed into the driver side wall of the trunk (there's a metal piece between the outside shell of the car and the fabric inside). I am using an Opus solutions case, which is to big to fit anywhere on the inside of the car. Even if I was using a smaller case -- I have an amp under the passenger seat, my DSP processor under the driver seat, DVD drive/usb hub/DSP control unit in my center console, USB UIRT/Car2PC behind monitor in the area that use to be the little cubby area, and the glovebox is actually used to carry stuff (ie: proof of insurance, tissue (for allegies), etc).
    I haven't had any issues concerning heat with the carputer in the trunk.
    Basically, I would like it to not look so *getto*.....
    Once I get my camera back, I will post some pictures and get some feedback on it.
    Nasa
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    One thing you have to do is make sure the HDD is on it side, so when you hit bumps the arm can move along the disk surface. If you have the HDD flat then the needle can slam down directly onto the disk, damaging the arm, disk or both.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Aug 2006
    PA
    Hi guys,
    To see what I presently am doing, please look at my worklog....
    http://www.mp3car.com/vbulletin/work...e-worklog.html
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    I attached my PC and amp to a piece of mdf like in Greatwhite's first pic. But it is on the opposite side of the board from his, and it hinges from the trunk floor. So when open it sits on the floor and when closed, you just see the back of the mdf covered with some trunk carpet. All nice and hidden. I put a 120mm fan in the middle to help cooling. I can't find my pics so I hope you understand what I'm saying.
    May 2007
    Boston
    does you setup still look like this?
    if so, I don't think that looks "ghetto" at all. I think it looks about as good as any trunk install could look. it's mounted vertically and it's compact. the only thing I would suggest is that you neaten up your wires/cables
  1. a warning to all prospective carputer installers!
    By mbkowns in forum General MP3Car Discussion
    Last Post: 08-19-2008, 05:37 AM
  2. Ideas on hardening trunk lid from exterior prying or lock cylinder pulling
    By jbeletti in forum General Hardware Discussion
    Last Post: 01-02-2007, 09:03 AM
  3. CarPC / InDash LCD / HU install in 1999 Toyota Avalon
    By jbeletti in forum Show off your project
    Last Post: 12-31-2006, 10:14 AM
  4. CarPC Brainstorming Ideas
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 12-27-2004, 03:40 PM
  5. some accessory ideas
    By moossmp3 in forum General Hardware Discussion
    Last Post: 09-08-2000, 06:27 PM
