i believe that would be the power to your cd changer. dont quote me on that though. but it would be to switch it on....
hello, I just recieved my CD-RB20 (enable you to use AUX on pioneer head unit, have RCA input while still have the CD Chnager function). It has a + Battery, +Battery Output and Ground. I looked at the instruction and it says the "Battery output is for connecting to multi-cd unswitched supply.
I am wondering if anybody have this and what does that mean?
if it helps, my head unit is a DEH-920r
thanx in advance
-Sike
Those battery wires are linked straight together inside the box.
Some units shipped with both the male / female connectors on one lead, and a female on the other. For those you can just disconnect the changer power supply and put the cdrb20 in between. For the other units that had a male on one wire and female on the other, you have to route the changer power through the cdrb20.
For reference: http://members.tripod.co.uk/cdrb20
Dave
I got one of these today and I know where most of the wires are meant to go but I'm confused to where I put the earth wire and the other one which is confusing is the a wire which the manual says you have to connect to the fuse box.
Also is it necessary to disconnect battery when installing?
THX
Hey,
I've figured where to put all the wires now...Can someone just give me some guidance on the Fuse Folder and wire which follows that.
On pic it is [#10 + #11]![]()
anyone?
I'm going to go out on a limb here and guess that you haven't done much car audio install before.
The earth (negative or) symbol is the return: the (-) versus the (+). In a +12v automotive system, as pretty much every car is, the entire body of the car is connected to the (-) side of the battery. So when it says to connect to earth, negative, ground, or whatever it may be called, it means to either (1) find a wire that is already connected to ground and splice into that, or even better is (2) to find some bare body metal and attach it to that. A good place is usually where something is bolted into the frame of the car. You can undo the bolt, place the wire there, and then replace the bolt for a solid connection.
Pretty much the ONLY line that is ever fused on a +12v automotive electrical diagram is the line supplying power to the device that needs power (that's your #11). The manual is telling you to attach this to the fuse box because they want to be clever and have you wire in a really (technically) nice system that uses the factory fuse box, along with the inline fuse that you have pictured that as #10. This is normally not easy, especially for a beginner, and to be honest, I never do it because then you risk overloading the fuse that you place it on. Car manufacturers use specific fuse values because they tested it with the equipment that they themselves put on that fused line. If you add your equipment to one of these lines, you either risk blowing the fuse by overloading it, or you have to increase the fuse value, and this then becomes dangerous to the rest of the preexisting equipment, because this equipment could now potentially overload and blow before the fuse does.
What's the solution? The clean, and often easier solution, is to run a new line from either the battery itself, or pull a big line from the battery to a power distribution block placed somewhere strategically in the vehicle. Then you can tap off of this. Either way, make sure that you place the fuse as close to the battery or distribution block as possible. This is because the wire could potentially short if it were to touch the body metal, so you want as short a run of wire as possible before the fuse. I learned this the hard way when a wire became stripped in my old car and I had a nice glowing piece of 18 gauge wire that burned through EVERYTHING along the path that the wire took from my battery all the way into my car, UNDER MY FEET, and then into the amp that it was powering. Had there been a fuse at the battery, it would have just blown and would have saved me quite a bit of damage. And yes, I was driving at the time. And yes, I FREAKED out...![]()
"Is Wayne Brady gonna have to choke a b@$#*??!!"
Hey,
Thanks for response. You're right but I gotta learn sometime.... I'll read through response l8r gotta work now but thanks!
Don't worry, wasn't meant as an insult! =) We all start from zero at some point. My first install was DISASTROUS...
