Results 1 to 7 of 7
Thread: Use HU?
    Jun 2008
    Use HU?
    Hi.
    How many are using the headunit to control the sound?
    Im am going to install my carpc soon and I dont know if i shell remove the HU or not.
    Can I get a clear sound without the HU?
    Sep 2007
    Dawson, IL
    Still running mine through the stock headunit(Monsoon(ie rebadged Delco)) - sounds pretty good to me. Will eventually redo my audio system but it is good for now
    Sep 2007
    Raleigh, NC
    I pulled my head unit out and havent missed it since. I use an external Sound Blaster Live and run directly to the amp. I briefly attempted to use the headunit, but found that it sounded horrible.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    it's all personal preference. some prefer to keep a HU with their carPC and others prefer a HU-less system...
    yes, you can certainly get "clear" sound without a HU. since an outboard amplifier is generally better quality than the small internal amplifiers inside a HU, your sound may be even better.
    there are pros and cons to each. keeping a HU allows you to keep hardware-based radio and volume controls but may be harder to integrate everything into your dash for a clean look.
    a HU-less system usually forces you to use software based radio, volume, and EQ controls.
    I personally hate software volume/EQ controls. I kept a HU in my previous system, but have gone HU-less for my current system. I compromised by using a 1/2-DIN pre-amp equalizer between the PC and amplifiers.
    whatever you decide, good luck
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Keep the HU if you can - you'll appreciate it IF the PC breakdown while on a long road trip.
    Jan 2008
    Southern Calif
    It all comes how your car dash is setup. If you have room for the monitor and a headunit, then you could keep the hu. But if you only have room for one or the other, then headless.
    May 2007
    Boston
    Quote Originally Posted by treetop777 View Post
    very true... as I've had that happen before
    but you can prepare for that by keeping a portable FM radio, MP3 player, CD "walkman", or SAT radio receiver in the car as a backup audio source, in an 'emergency' you can always feed that straight into your amp.
    I use a Pioneer Inno portable XM receiver which is normally connected to my carPC's line-in jack, but one time I had to use it as a direct XM>amp audio source when my carPC wouldn't turn on (it turned out to be a loose pin in my case's I/O power connector )
    I also keep a cheap pocket FM radio in my car as well. in the rare event that my carPC AND amp should fail to work, I will still have some form of audio available. I haven't had to use it yet (at least not in the car ), but it's always there if I need it ...
    I go crazy driving even 1 mile without music, so I stay prepared at all times
  1. HU to PC or PC to HU
    By aqus in forum Car Audio
    Last Post: 09-08-2007, 04:46 PM
  2. Is my HU dead?
    By Cheekz185 in forum Car Audio
    Last Post: 10-07-2006, 08:09 PM
  3. Problems on Carputer to HU
    By Grimoire in forum Car Audio
    Last Post: 05-20-2006, 04:35 PM
  4. car-pc to monsoon HU rundown *nooby* alert
    By Jamazon in forum Car Audio
    Last Post: 05-02-2006, 08:21 AM
  5. Replies: 21
    Last Post: 07-22-2005, 01:35 PM
