I did some informal
testing today with an old 2.5 drive in a usb enclosure because I was curious.
I believe that when you mount your drive vertically, you may prevent the heads from slapping into the platters, but may also lower the performance of the drive due to the increased read/write errors during shock (as the head bounces around missing its intended tracks, and ECC has to cover for it). Just by shaking the drive up and down, I was able to get read/write speeds up to 50% lower than what they were when the tests were done with the drive stationary. Shaking the drive more violently made the speeds even lower.
Try it yourself, there is a free drive speed tester called CrystalDiskMark.
