Results 1 to 5 of 5
Thread: Serial Port issues, Please HELP.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I have started to have serial port issues. When I first start the PC, everything works, XM, HD Radio, OBD2 and AMP_CTRL. If I open anything that is serial, it will freeze after a certain amount of time. At first I thought it was CF, but then I tried Mitch's HD Radio application and after 2 minutes I tried to change the channel and his app frooze. My setup worked perfect, the only thing I can think that could be the issue is that I started to use AMP_CTRL, before I used Volume_Amp_Ctrl, could that be the issue? I also started to use a device called a PAC TR-4, its a remote trigger for all of my AMPS. http://www.buy.com/prod/pac-tr-4-low.../90129363.html. Only other thing I can think of is that the PAC TR-4 is not connected correctly. I have the green wire connected to pin 4, then it has a ground. Should I connect this ground to the ground on the serial port? currently I have it connected to my distrobution block. What else should I try to do to trouble shoot?
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
    Mar 2006
    Blog Entries
    1
    What kind of serial ports? Are they built in serial ports from the motherboard, or are they some sort of USB-serial adapter?
    For troubleshooting, disconnect all other serial "stuff" so you can determine where the problem is. ie. Work with one serial device only, unplug the rest. This will eventually tell you where the problem lies.
    Jul 2007
    Miami
    Quote Originally Posted by BlackStealth View Post
    These are serial ports on the MoBo. I have a feeling something is wrong with them and rather then waste anymore time I bought Serial to USB adapters. For some reason after a certain amount of data has gone between the device and the port, the app that is being used will just freeze because the port cut out or something. Only thing that works is port 4, which is the AMP_CTRL, I guess because there is no data transfer it doesnt give out.
    4x 10inch Tablet
    Jul 2007
    Miami
    I think maybe I have found the issue. Its a IRQ issue. I notice that when i have the USB PCI card plugged in, the sound card works in 24 bit mode. As soon as i plug in a serial device, the soundcard will go into 16 bit mode saying that bandwidth has been limited and must go into 16bit mode. I guess maybe i should try without the USB PCI card. I am starting to think this is the issue. i originally had a 5 port card, but it was fried. I then downsized to a 3 port card and have had issues ever since. When I get home, i am going to unplug the PCI card and see what happens.
    4x 10inch Tablet
    Jul 2007
    Miami
    OMFG, it was the USB PCI card. As soon as it was unplugged, all serial ports work. Also my graphic card issues have gone away. Going to buy a new USB card.
    4x 10inch Tablet
  1. Bluetooth Serial Port Nightmare, IOGEAR, Zoom
    By matt621 in forum General Hardware Discussion
    Last Post: 07-05-2008, 07:55 PM
  2. XM solutions - no serial port available
    By FockMasterDan in forum General Hardware Discussion
    Last Post: 06-05-2008, 02:02 AM
  3. Sprint Touch BT Serial Port Trouble!!! Please Help
    By compman723 in forum Wireless Communications
    Last Post: 02-08-2008, 10:09 PM
  4. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 04:47 PM
  5. Can I pull out 200mA from serial port of Epia 10000?
    By slimmegane in forum Hardware Development
    Last Post: 10-24-2005, 10:25 AM
