OK, after considerable effort and going at this again with a clear head today (I never drank last night) I managed to dismantle this thing and locate all the pieces of the broken drive gear. With creative use of crazy glue and two part epoxy, I have glued the gear back together, then used a hack saw blade to remove excess hardened glue from the teeth on the gear. After some fine filing I now have the gear re-bonded to the motor and the motor re-installed in the unit. I am just in the process of putting the unit back together and then will powering it up for a test run. I epoxied the gear to the motor shaft for extra re-enforcement of the gear. The reason that these gears are breaking like that is because the shaft hole in the gear is too small for the shaft, so when they press the gear onto the shaft the gear splits due to too much pressure. I slightly enlarged the hole so that it still fit tight on the shaft, but not so tight to crack the gear. Wish me luck.
LinkBack URL
About LinkBacks
