Are you sure it is a short? I had this same thing with my first install. It turns out it was the connector to the PC being loose and also a molex cable's pin had slipped out of its holder.
If you boot into the BIOS, and leave it on some page like the PC Health page or something and drive around, will it restart? If it doesnt restart, then power to the PC is ok. That means usually a HD or RAM problem. Could be loose RAM (not seated 100% correct, or maybe jiggled loose with cheap boards), or the HD connectors for both data and/or power are loose or have a bad connection somewhere between PSU/HD_Power and/or mobo/HD_Data. If windows loses its main HD, it dies and restarts.
So since you already did the checking the cable for shorts and such I think the PC itself is the next logical choice. However to answer your original question, I would specifically check the firewall. Wire through parallel sharp metal can mean trouble if not properly sealed. Other things is maybe have a little light hooked up to your power cable where you can see and then ground the other end. If the light flashes then it got grounded through power and you do have a short. Or a small speaker and when it shorts it will make a screech/scratch.
I know how frustrating that can be, I hope you sort it out!
LinkBack URL
About LinkBacks
