Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: LONG RCA Cables
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    LONG RCA Cables
    I was wondering where I might obtain some bulk sheilded RCA cable that I can add the connectors myself. I bought one of those 2.4 GHz audio/video transmitters to watch movies on the TV in the living room from the computer in my home office. Anyways it doesn't play well with the 2.4 WiFi network (or the 2.4 cordless phones, etc. etc.) Since that is a no go... Can I run some RCA cables about 75 - 100 feet, and if so where can I buy some cable that I don't have to pay $1.25 a foot for?
    Jan 2003
    Ruston, LA
    Runs that long without an amp is going to lose some signal quality
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    So I fix it with an amp. I just need a cost effective solution
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    100 feet you will have no need for any amp. I have done this in the past but with s video cable. People said its imposible until I built my own cable.
    RCA is easy. It only invovles 2 wires if you can find the right wire, remember the shield itself is the gound and the center conductor is the signal, or the center pin. Try out home depot, they have tons of wires and at good pices as well.
    What is RCA on your computer?
    Edit: Here you can get a 50 foot long calbe, then get yourslef a female RCA to female RCA adatper and hook up another cable.http://www.trianglecables.com/svidsvhscab.html
    This would be much easier than building it yourself.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    RCA = tv out
    Feb 2003
    South Florida
    its rca and not s video out? what video card are you using? ATI all in wonder?
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    S-video usually uses a 4 conductor mini-din connector, whereas TV-out (which is often composite video) uses RCA. Those cables you posted are not RCA, they are s-video connectors.
    Composite video modulates the chroma on top of the luminence signal, which is why it only needs two wires (ground and signal), whereas s-video keeps chroma and luminence separate (which is why you need more wires).
    Rob
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    I'm thinking shielded cat5 cable.
    Dec 1999
    Buena Park, CA
    Stop thinking that right now! Cat5 is totally inappropriate without the use of expensive converters.
    My general rule of thumb is 150' for composite video without the use of an amp, and has worked well in some of the larger ballrooms I work in. If you go to Parts Express, as I recall, they have crimp on RCA video connectors. You can also crimp on F connectors, and use adapters.
    KG6OQD
    www.americansandassociation.org
    Feb 2003
    South Florida
    Originally posted by Rob Withey
    Those cables you posted are not RCA, they are s-video connectors.Rob
    Shure looks like RCA to me, plus the S video cable included.
