Results 1 to 10 of 16
Thread: Wake Up On LAN
    Feb 2009
    Wake Up On LAN
    Looking through my BIOS I see the wake up on LAN. If I enable that, and have a ethernet cable thats cut so there just an end - If I plug that in will it turn on my PC?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Try it out and let us know. I have a laptop that has that, but it only works to bring the computer out of standby, not from a full shut off.
    RevFE
    My Shop
    Elsewhere
    Quote Originally Posted by DocShay View Post
    No.
    WoL detects a signal on the LAN port, which means you would need voltage (albeit a tiny amount) on the Cat5.
    A cut off piece of cable isn't going to do it.
    How about the Wiki?
    Jun 2004
    Westminster, MD
    Whups I misread
    RevFE
    My Shop
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I believe that signal needs to send the 'magic packet' in order to wake it up.
    I've seen people use an old router and have it hooked up to the ignition. That sends the packet when it wakes up.
    Want to:
    Jun 2004
    Westminster, MD
    Quote Originally Posted by Bugbyte View Post
    Yeah I'm thinking Wake On Link, not Wake on Lan
    RevFE
    My Shop
    Feb 2009
    Hmm, would it be a terrible idea to try and splice into the end of 1 end of the Cat5 to 12v ignition source, and plug the other end into my LAN in attempt to wake it?
    Does it need the magic packet, or just a small voltage from the line?
    Feb 2009
    I remeber seeing a picture of a guy with the router in his trunk doing this..
    Any idea how to set this up? Googled abit and tried to understand it...but im getting no where.
    I have an old linksys WRT54gs around. I enabled Wake on Lan on my bios. Read an article to forward port 9 to 192.168.1.255 (Which the router won't allow me to do). They mentioned this would happen so you need to setup ARP or something? This confuses me..
    I just want to be able to plug in ethernet from the router which has power...to start up my laptop. Seems I have all the necessary hardware...just don't know how to complete this!
    Elsewhere
    Quote Originally Posted by malcom2073 View Post
    Don't feel bad. So was I.
    This would likely destroy your motherboard or network adapter, as the voltage from the car would be much greater than the network adapter could handle.
    Wake on LAN requires the magic packet.
    Here's a good resource on port forwarding: http://portforward.com/
    Don't know why the article said to forward a port to that address. That honestly makes no sense.
    I'm willing to bet that you need to forward the port to your PC, but I also haven't read the article.
    How about the Wiki?
    Feb 2009
    Figured it out..took awhile but I got it.
    The reason it you need to forward 192.168.1.255 is because thats the routers broadcast address. As a security feature on the linksys router, that port is disabled. So I upgraded the firmware to DDWRT, which has this along with a bunch of Wake on Lan settings.
    Enabled Wake on Lan on the router, and on my laptop. Inputted my MAC adress from my laptop into the router, put in the broadcast port. You can also change how often the router looks to see if the computer is active/in sleep mode.
    So...hook up router to my ignition. Router turns on, see's laptop is in Sleep Mode, router sends packet to laptop...takes it out of sleep mode. When I stop and about to turn my car off...choose sleep mode on the touchscreen. turn car off.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Remotely startup laptop...? (wake on lan)??
    By Pro in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-13-2006, 07:57 AM
  3. Laptop powerup by wake on ring or wake on lan
    By ZeroDefects in forum Power Supplies
    Last Post: 08-25-2005, 11:01 AM
  4. Will 802.11n support Wake On Lan?
    By Danceheaven in forum Wireless Communications
    Last Post: 03-01-2005, 12:19 AM
  5. Wake Up Lan
    By CorollaVerso'04 in forum General Hardware Discussion
    Last Post: 06-21-2004, 09:43 AM
