well, it should be fine if you have the exact same motherboard, if not, you will get an error message once the new motherboard is installed. i don't have a link at hand, but some say that it's possible to "repair" the install, (get the setup of the pc to work with windows) but i would recommend to do a clean install on the new setup once you have it, that way you won't have any hiccups driver wise. and once you are sure you have everything correctly installed and working perfectly just burn an image of the installed os-drivers on a dvd for backup.
LinkBack URL
About LinkBacks
