Results 1 to 10 of 12
Thread: Got motherboard today, having problems.
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    I got the Intel motherboard and M4 ATX power supply in the mail today. So I hooked everything up including the SSHD hoping to begin installation of Windows XP.
    I tried using the CD drive from the desktop as a temporary drive to install XP, but it said "No bootable device found, insert boot disk and press any key" or something like that.
    I tried connecting the hard disk from my desktop computer but then I get a blue screen asking me to restart the computer.
    What am I doing wrong?
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Any number of things 'might' me the issue.
    Check all the cables: power, drive and such.
    Unseat then reseat the RAM
    Try a desktop power supply.
    That is where I would start. I suggest doing all of this at your desk and not in the car, in case you are not already doing that. Be prepared for working on this awhile until you get it right. Do not rush and if you get frustrated, walk away and come back later.
    Cheers
    TruckinMP3
    Read the FAQ!
    Feb 2006
    I have already reseated the RAM. I have played around with master/slave settings in the BIOS and changed the jumpers on the hard drive and CD drive. If I put the jumper to "cable select" and don't have the correct IDE plug in the drive, it will hang on a black boot screen with a still cursor.
    Jun 2002
    Colorado
    Cable select is known to do that.... My suggestion is not use that setting.
    If you have been changing BIOS settings I suggest returning it to defaults and try again.
    TruckinMP3
    Read the FAQ!
    Feb 2006
    Defaults were reset and still the same thing. It's not recognizing the XP image on the hard drive or the XP CD in the CD drive.
    Jun 2002
    Colorado
    Well, either you are missing something or some part is not right.
    swap out each part one at a time with a known good substitute (if you have one).
    try a different OS disk, you might even try each of your new parts on a different PC to see if they work.
    If all of that does not point out the issue, start RMA process.
    TruckinMP3
    Read the FAQ!
    Feb 2006
    I contacted Intel Tech Support and they said the board I'm using won't work with anything older than Windows XP Service Pack 2, and I happen to have XP before SP2. I'll try SP2 and see where that gets me.
    Mar 2009
    near Rochester, NY
    that's a SATA drive - you shouldn't be doing anything with IDE settings such as master/slave or cable select
    Feb 2006
    The problem was with an IDE drive I hooked up.
    Feb 2006
    Ok, figured out the problem. The motherboard doesn't support anything older than XP SP2, but it started up the install when I tried my brother's XP SP2 disk. So I ordered Windows XP SP3 off Ebay. It'll come at the beginning of September.
  1. Good read on ground loops
    By coffeejolts in forum Car Audio
    Last Post: 04-28-2008, 02:30 PM
  2. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 05:06 PM
  3. Hardware Review: Commell lv-668 1500NX embedded motherboard
    By wilsonj in forum The Review Palace
    Last Post: 07-03-2006, 07:36 AM
  4. REplacing motherboard...problems?
    By Skipjacks in forum General Hardware Discussion
    Last Post: 01-08-2005, 02:27 PM
  5. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 08:56 PM
