Results 1 to 10 of 15
Thread: Need solution for lack of power and IDE ports.
    May 2006
    Calgary, Alberta
    Hardware in question: DG945GCLF, M2-ATX, IDE laptop drive
    I just sold my M10000 motherboard and M1-ATX and bought this new motherboard and power supply. I'm trying to put everything together today but I have a few problems.
    Problem 1: There is only 1 LP4 power connector on the power supply, the other 2 connectors are SATA. I have to use LP4 power connectors to power my Xenarc 700TSV and my IDE hard drive. How do I work that?
    Problem 2: It appears that since I changed to a 64 bit board and processor that my hard drive will no longer boot on the bench. I get a blue screen that I know is a result of the architecture mismatch. So now I need to reinstall Windows which means hooking up a CD drive. I have an extra drive here but it's IDE and there's only 1 IDE port on the motherboard. I need to hook up this CD drive and my hard drive to IDE. Can I use another 64 bit motherboard I have to install Windows and then swap it back?
    Am I better off just buying a SATA laptop drive to solve both problems?
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Problem 1: LP4 Y adapter, sold at your local rat-shack (radioshack, or other electronics type store)
    Problem 2: Known issue with windows, you can't install on one motherboard and move to another. To reinstall: dual device IDE cable SHOULD work. Make the HDD master and the CDrom slave.
    Yes, you're better off buying SATA, but there are solutions if you wish to stick with IDE
    Quote Originally Posted by mitchjs
    stop with the REINSTALLS, what do you think we got some lame-o installer!!!
    RevFE - Super fast, modular frontend. Most powerful skinning engine in existence. Strong enough for an i7 made for a fitpc.
    Just a shame I can't justify a carpc to use it on anymore.
    May 2006
    Calgary, Alberta
    I just realized I won't be able to hook up a dial IDE cable because the connector on the hard drive is a mini connector while the other end is a normal size. I don't have any dual cables like that. I'm trying to work with what I have which is a box full of regular computer parts.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Maheriano View Post
    Well I have a quadrillion Y adapters. Actually I will be driving northwards Tuesday, probably be in the Toronto area Wednesday night and all day Thursday this week if you need me to give you one.
    Also every geek should have IDE converters, external enclosures, that sort of thing.
    Anyways, the easiest way to install windows in your case, is to hook up your harddrive to another fully functional NT based computer as a slave (basically just another drive, not bootable drive). Then format your drive (a quick NTFS format will be fine unless you know there are bad partitions that a full format's MBR indexing will help with). Now assume D: is your CarPC harddrive you just formatted, and E: is an optical drive with the XP CD in it. Type the following into the command prompt (needs admin privs under Vista)
    Code:
    E:\I386\winnt32.exe /syspart:D: /tempdrive:D: /makelocalsource /noreboot
    XP Setup will startup, choose Full Install, go through the rigamaroo, and type in your CD key. After that, it will take some time and it will start copying files and such. When the XP window disappears and shows you your regular desktop, then you can power down your host computer, remove the CarPC drive, and put it in your new PC. Start it up, and XP installation will resume.
    It basically does all the setup from the blue loading screen, EULA, CD Key, and copying all files until it says "remove disk and your computer will reboot in 15 seconds" and counts down. So all you are doing is saying do that part, but leave it alone when you are done. Then when you put it into anything else, it starts right back up like it was there the whole time. Simple trick.
    And if you dont want to buy Y-adapters you can just hack up some clips from a donor PSU and solder them into your CarPC's PSU. Really doesn't matter.
    EDIT: Nevermind, I see you are in Calgary. I thought you were in Toronto for some reason... Rest of it holds true though
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Calgary, Alberta
    So I've resorted to the following:
    - I just bought a LP4 power splitter in case I don't end up getting a SATA drive.
    - I rounded up a 80 gig SATA laptop drive for $15, supposed to be picking it up tonight.
    - I'm creating a .iso image of Windows XP, using my Ubuntu bootable USB creator to turn my USB stick into an installer, going to plug that into the machine and hopefully eliminate the need for the CD drive. I'll install Windows to the IDE drive for now in case I don't get the SATA drive tonight for whatever reason.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    May 2006
    Calgary, Alberta
    Well that didn't work, I should have known Microsoft would find some way to **** me off.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Jun 2004
    Westminster, MD
    That's unfortunate, I tried installing from a USB stick a while back and had no luck either.
    Mar 2006
    I've installed from USB stick before, but it is extremely slow.
    I'm telling you the easiest way is just put the drive in a host PC and start installation like I mention, then move it back. Works everytime and is very fast since it is internal transfer speeds, not USB conversions.
    May 2006
    Calgary, Alberta
    Quote Originally Posted by 2k1Toaster View Post
    Well that's how I installed Ubuntu on this laptop I'm using, it was from a USB stick. But Microsoft must have done something with their CD to make it so you couldn't do that with the .iso image. All other .iso worked fine for me in the past.
    Sorry, I should have explained to you why I didn't use your idea. You said I need another NT based machine. I got 5 computers and all of them run Ubuntu except my car computer. Don't have another Windows machine unfortunately.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Well these are the headaches you get when you go away from M$.
    You could always download the XP floppy install which does the same thing but with 10-14 floppy diskettes.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Intel D945GCLF (with integrated Atom 1.6Ghz CPU)
    By PORTUGAL in forum General Hardware Discussion
    Last Post: 05-18-2009, 11:05 AM
  3. Replies: 0
    Last Post: 01-16-2009, 11:48 PM
  4. Bytecc BT-200 USB 2.0 to IDE Adapter power?
    By hauler34 in forum Input Devices
    Last Post: 11-07-2006, 02:02 PM
  5. Replies: 5
    Last Post: 12-24-2003, 02:02 PM
