If your getting BSOD during OS install, 9 times outta 10 it's bad memory...
Try another stick, or double check your RAM timings in the BIOS...they maybe too aggressive.
ok ....i have bought the little falls 2 from intel fro mocoso...
also have a 1 gb ram 667 kinkston and a ocz ssd solid serie!
i have formated the pc like 15 time because theere are always blues screen that appears...
sometime it is ok....tometime the blue screen comes afeter the windows log on....
sometime when i am in audiomulch....
the blue screen do not really show the same error at each time !
i noted two error today...
kernel_data_inpage_error
session3_initialisation_failed
there is no way to know what is the problem...because sometimes it is there and sometime it is not.
do you have any idea....i would like to play with the carpc more than one week...
check the RAM anyway!
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
what is the best 2gb ram , i can put into the Intel D945GCLF2 mobo»?
1GB is plenty for a car PC, especially when using hibernation...
Kingston is good...maybe you can RMA it?
OCZ, Mushkin are also good...
Check your mainboard specs for compatibility as well.
i have a 1go module now..
i wanted a 2go because i dont use ibernation...(but maybe later i will)
i know that my mobo accept until pc5300 ram...but i saw in some forums that there are people wich uses pc6400 on it...and there are not so much pc5400 in stores.
what is rma?
ok it is a return
thnakls for your help..i will put the ram of my home pc in my carpc to see how it goes
I bought some cheap Crucial ($17 for 2GB) memory from newegg for my LF2. Its been running pretty solid. Also are you using IDE or SATA for the HDD? If it is IDE try another cable even though it sounds like a memory issue.
Here's the memory I ordered but it looks like it has gone up in price
http://www.newegg.com/Product/Produc...82E16820148236
2006 Mustang with indash CarPC
