Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: High current detachable power connector? To hook up car to house power.
  1. #11
    May 2007
    a decent electronics store should carry the anderson sb-175, which is probably the connector pictured in your link (might be a larger size) i used them to build a pass through adapter to run a radio on my pallet jack at work. the're rated for 175 amps at 24v and shouldn't run you more than 10 bucks each.
  2. #12
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Thanks for the suggestions. While we are on the topic of hooking up the car's electrical system to the house, is it safe for the alternator to remain connected? It should have diodes to prevent back emf right? aka. current going into the alternator.
  3. #13
    Dec 2008
    Quote Originally Posted by nobb View Post
    yes they must have that feature or it will pull enough current from the car's battery alone to flatten it in a few hours. this happens with bad or broken alternaters sometimes.. the diodes burn out and you always wake up to a dead battery in the morning.
    may i ask again why an onboard charger wont work?
  4. #14
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Ideally, I would love for the charger to be onboard. But unfortunately my battery charger is huge (volume of a big shoebox) and I have no where in the engine bay to mount it. Unless someone knows of a 15+ amp high current charger that is also very slim and compact.
    Trader007, the charger in your link is only 10amps and costs $120. I could get two 12 amp chargers from Canadian Tire for the same price =)
  5. #15
    Jan 2008
    Dartmouth, MA
    What are you driving? You could always put the charger in the trunk if it's not a pickup.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  6. #16
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    2002 Mazda Protege sedan, very cramped engine bay and Ive already got too much crap in the trunk, like aux deep cycle battery and subwoofer. Rather not have to give up any more trunk space if possible.
    It's not too big of a deal to have the charger externally.
  7. #17
    Low Bitrate IssaquahWA1979's Avatar
    Oct 2009
    Issaquah Washington
    if you want an on board solution look to the marine chargers like the Statpower True charge etc. There are also a bunch that are just a charger epoxy sealed that would survive the engine bay life.
    My truck I have a Statpower Truecharge 40 and a recessed male receptacle in the bed so all I do is take a regular extension cord and plug it in. I am in the process of doing a rework on it though as I want to tie in my battery blanket/engine heater into the circuit with the ability to temp control it so it only comes on in cold weather; 7amps for the heaters is a lot to run for no reason. The other I want to change eventually is to change the inlet socket to a auto-eject but they are $$$
    Custom Built Intel D510MO, 2GB RAM, M4-ATX, Elios 15" TS on custom mount.
    System installed into 2005 Dodge Ram 3500 Cummins Diesel 4x4.
    I can provide Custom fabrication for mounts or installation please contact me. CNC Machining and Powder Coating
  1. VW Jetta
    By dMand in forum Show off your project
    Last Post: 12-11-2009, 06:02 AM
  2. Replies: 5
    Last Post: 03-06-2009, 05:15 PM
  3. Hardware Review: M3-ATX Power Suply
    By Bimmerstyle in forum The Review Palace
    Last Post: 03-05-2008, 06:57 PM
  4. NIB M2-ATX DC-DC ATX auto car PC power supply mini ITX EPIA
    By ichiban in forum Classified Archive
    Last Post: 07-21-2006, 01:00 PM
  5. What to look for in a PSU some info for you
    By cproaudio in forum Power Supplies
    Last Post: 04-04-2003, 02:07 AM
