Results 1 to 10 of 13
Thread: Determining current draw.
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    I have all my carputer parts and right now I'm in the planning phase of installing everything. I am currently determining where to mount everything and how to wire it up. My current plan is to run one primary hot wire from the battery through the firewall to power a few devices I intend to install, including the carputer. It will run to a distribution (fuse) block and will branch out in different circuits to power each device.
    How do I determine the peak current draw of the carputer? I want to run the right gauge wire accordingly for the carputer. I considered just using the stock radio power wire, but I read some other threads and figured it isn't large enough for the carputer's peak current draw.
    For reference purposes, I have this motherboard and this power supply.
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
    Newbie V1RUS's Avatar
    May 2008
    Florida
    You do no want to use your stock radio wire, I ran 4ga back then fuse split to 8ga. I use the same atom motherboard in my truck also running the screen off the power-supply and it draws 36W on average. That m/b does not draw a lot of power, but the more you hook up (hd's, cd drives ect) all ups your consumption.
    2005 Silverado - Atom 330 D945GCLF2 - 160GB Hitachi 2.5" HD - 150W Opus PSU - Lilliput 629GL
    Feb 2006
    Is it a safe assumption that the most power drawn will be peak at 300 watts per the power supply specification?
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by stonestatue View Post
    Are you running everything off the power supply? Or will some devices be hooked up separately?
    Edit: You shouldn't be able to draw more power from the power supply than it can output. So the 300 watts should be about the maximum for your carpc even though it will most likely be much less. So (not considering efficiency), that power line could draw 25A. Based on http://www.mp3car.com/vbulletin/advf...iew&advfaqid=5 , that power line should be at least 10 gauge. Make sure to fuse all power lines.
    Feb 2006
    I'll run everything I can get away with off the power supply. Here's a list of things I have so far:
    - motherboard: 36 watts
    - DVD burner: (stated on bottom of drive: 5 volts 1.6 amps (8 watts)
    - solid state hard drive: current draw unknown
    - Lilliput touchscreen monitor: 9 watts (.75 amps)
    - HQCT USB radio: (quoted from website) Stand-by: < 10mA
    Playing: 70-80mA on 5V line, 80-110mA on 12V line
    - 41hz Amp 9 kit: current draw unknown
    - USB audio selector: current draw unknown
    - Fusion Brain 4.0: current draw unknown
    - USB GPS: 80 milliamps
    All of this I will try to put in the carputer case and run off the power supply. However, I might put the Fusion Brain in a separate case for ease of accessibility.
    Feb 2009
    Since you have a fusion brain, there is a current sensor you may want to look at: http://www.fusioncontrolcentre.com/F...products_id=45
    Feb 2006
    I do intend to fuse the power supply even though it's internally fused. It will be one of the fused circuits coming from the distribution block. Let's say something causes the carputer circuit to blow a fuse. Seeing as how it's got two fuses in the circuit, one at the block and one on the power supply itself, both rated at 25 amps, which one would blow first?
    Feb 2009
    Maybe someone else would have a definite answer. This is just my best guess: I'd imagine the fuse closer to the power source. So in this case, assuming it's the same type of fuse, the one at the block. Maybe if the fuses were made of different materials or different quality, which ever heats up first. But again, that's just my best guess.
    Feb 2006
    Well thanks for your input. I have at least begun an inventory of what my carputer will consist of and what most devices are rated.
    Feb 2006
    Just checked the bottom sticker for the DVD burner, and it says "5v 1.6 a". I edited the information I posted accordingly.
  1. Release new phoco integration preview
    By Robby BMW in forum Road Runner
    Last Post: 09-12-2009, 06:29 AM
  2. A Question about Current Draw
    By deep6 in forum Power Supplies
    Last Post: 08-29-2006, 12:03 AM
  3. Current draw when PC is off/in hibernation.
    By Arathranar in forum Power Supplies
    Last Post: 01-25-2005, 04:21 PM
  4. No Load Inverter Current Draw, how long till it kills my battery
    By clean customs in forum Power Supplies
    Last Post: 01-14-2005, 01:57 AM
  5. Battery Current draw when parked - info needed
    By Pabs in forum General Hardware Discussion
    Last Post: 12-16-2004, 07:03 PM
