I guess this to hard to do?
As you may know, I am trying to remove all my mirrors and go for a 100% camera based system. My design has changed so I am adding equipment to it. First off, on the screen I only wanted to see a 3-way view, which is left, rear and right. I wasn't concerned about covering the front, because I am looking at it physically with my own eyes. I then decided a DVR would be great to monitor my driving, for safety concerns. That would require a 4 way view though. So now I am adding another DQP specifically for the DVR. It will see 4 way, then my DQP will see 3-way.
Here is my question. Currently the DQP (Digital Quad Processor, used for security systems) automatically starts off in 4-way view. I want it to start in 3-way view instead so I do not have to hit a button all the time. Is there anyone that is willing to try to reprogram (rewire) the unit so it starts off in 3-way view by default?. I would gladly pay someone to do it for me. Basically when power is applied, it goes straight into 3-way reliably.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
I was thinking.... maybe its to much work to rework the board its self. Maybe some one can create a relay system that can accomplish the same thing?
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
is it just one button press or more than one? and how soon can you press the button to get to the 3 split?(as soon as theres power, or you have to wait a couple seconds for the systme i initalize, or can you press it as the quad is stating up?)
You can probably use a capacitor to discharge and press the button for you when you turn the system on. Look up the old way to auto-turnon the lilliput monitors before it was a feature of the monitors.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
Here is the hard part. Basically when I apply power to the DQP (ignition) I want it to change over to 3 way mode after 1 second. The issue is that the relay has to release immediately. Basically I have made it so you can wire up the relay to the unit button (it is one single button), the issue is that the same button also serves another function if held for 2 or 3 seconds. So far relays will not release fast enough so the DQP goes into a mode I do not want. In the relay's defense though, it may just be because i do not know what I am doing, and thats why it releases so slow.
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
If you don't mind doing some circuitry you can probably use a FET and a counter IC. You can have ur turn on signal initiate the counter and activate the FET and then have the last bit in the counter( less than 2 secs) deactivate the FET. I could draw up a schematic if you want.
~The Build Process Begins~
http://www.mp3car.com/vbulletin/newb...you-think.html
~The Build Process Ends~
http://www.mp3car.com/vbulletin/show...completed.html
Could be accomplished using a 555 timer to output a 1-shot (monostable) pulse. You can configure how long to hold the pulse via external circuitry.
http://www.kpsec.freeuk.com/555timer.htm#monostable
CarPC v2.5 up and running - all hardware installed, skin configured, and iG tweaked like crazy. Now for OBD-II, and voice control, and camera plugin, and... :nutz: - it never ends!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
