Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: baddest sytems I can build?
  1. #11
    Sep 2009
    Quote Originally Posted by afterdigital View Post
    @STZ With that said, i've had my eye on the Nvidia motherboard for the main reason that it's NVIDIA - a video guru company. Their reputation exceeds them and creating a motherboard around their video technology is one interesting approach. Their mobo however uses Atom, which IPO, is not a bad thing. The mobo is capable of 4gb of ram (ideal for Win7). Has dual screen built in (drooling)... And due to it's processor and small form factor - i would venture to guess that power consumption may be ideal for a car pc.
    Here's a link to the mobo by Zotac with Nvidia ION @ newegg:
    ZOTAC GF9300-D-E LGA 775 NVIDIA GeForce 9300 HDMI WiFi Mini ITX Intel Motherboard - Correction: This MOBO goes up to 8gb! woot woot!
    High five to that! Cheers, I've been looking at the lower spec one of those (also a fan of Nvidia) and hadn't come across this gem!
  2. #12
    Jan 2009
    nice find!
  3. #13
    STZ
    STZ is offline
    Mar 2007
    That Zotac board is the one that I am looking at.
    The PC is going in the cabin of a boat (doesn't need to be ruggidized as it's dry) It does however have to be small. I am thinking of using an external DVD burner so that it can be remotely mounted away from the computer itself.
    It's main job will to be running a program called MAXSEA. It gets data from the internet via sat, then desplays it, routes etc on the computer. The computer they have now is slow at running it. I'm sure a C2D would be adequate. My main concern was the heat sink.
    examples of the boards with the c2d built in? cost isn't so much a factor here provided it is justifiable. I already mentioned SSD and they shot that down as unnecessary.
    My main concern was the heat sink and it's size. That M350 Case will probably be how I proceed, but now, it's board and proc selection.
    It will be running XP.
    Sorry for the out of order thoughts, I just typed as things came to mind!
  4. #14
    Jun 2008
    Seattle, WA
    The M350 can fit a stock heat sink and fan for most CPU's with a TDP of 65 watts or less, so you're good there. Also, low-profile heat sink/fan combos can be had on Newegg for $20-$30.
    Unfortunately, I'm pretty sure the M2-ATX won't fit in the M350. You'd probably have to go with a PicoPSU or the M3-ATX.
  5. #15
    Jan 2008
    Wow, that is a pretty hefty program! what are the specs of the system they are using now?
    What is your budget, and space requirements? (i know you need it small, but we would need dimesions of the install area)
    and for anyone else interested, here is a copy-paste of the minimum and recomended requirements
    minimum:
    Processor: 32 bits (x86) 1 GHz cadenced
    RAM Memory: 1 GB
    Hard Disk Capacity: 40 GB
    Video Card: DirectX 9 (WDDM driver, Pixel Shader 2.0 and 32 bits per pixel); minimum graphic memory :
    MaxSea Navigator : 128 MB
    MaxSea Explorer : 256 MB for NavNet3D radar display
    Screen Settings: 800 X 600 / 16-bits
    CD/DVD - ROM Drive 24X recommended for MaxSea Installation
    Operating System : Windows XP x32 SP2 or Windows VISTA 32 capable / Windows VISTA 32 Prenium Ready Computers.
    Used Ports : USB / Serial
    Network Ethernet 10/100 Mbits connection Base-T
    recomended:
    Processor: 32 bits (x86) 2 GHz cadenced (Core Duo)
    RAM Memory: 2 GB
    Hard Disk Capacity: 120 GB
    MaxSea Navigator : 256 MB
    MaxSea Explorer : 512 MB for NavNet3D radar display
    Screen Settings: 1024 X 768 / 32-bits
    based on the recomendations, i would say that you should plan on using a video card, instead of onboard graphics, and at least a core 2 duo processor, and a gig or 2 of ram. Will they be using the computer to do anything else? Than you will need a even heftier system... also, i am not completely familiar with the program, or satillite interent, but the slow speed could also be related to the program relying on the internet connection-- i know that satillite ISP Hughesnet (sp?) has horrible upload speeds-- so if the program has to send large ammounts of data, the network could be the cause.
  6. #16
    STZ
    STZ is offline
    Mar 2007
    that's the most intensive program
    the rest is just email, picasa, browser, etc and won't be at the same time.
    I think you copied the same specs twice as they look identical to me!
    The sat system is called a Fleet 33. It is slow, but downloads the data once, then has to regen the maps and things. That's what takes all the power. While slow, it's amazing that you can still get net in the middle of the atlantic!
  7. #17
    Jan 2009
    do you(anyone) think that they will make a i7 sk 1156 of the mini form factor one day?
  8. #18
    Variable Bitrate afterdigital's Avatar
    Aug 2006
    New Ro, NY
    ok - maybe i wasn't paying attention to "where" this application was being setup (or it wasn't mentioned).
    A boat is very different from a car for several reasons beginning with the specific program "MaxSea" that you mentioned (and i've never heard off). I'm sure the program states requirements (in hardware) and it would probably be a good place for you to start.
    CTS 05, Mobile Information Center...
    Atom - 1.8ghz
    2GB Ram
    32GB SSD
    8" TouchScreen
    5.6" Screen (overhead) w/reverse capability
    Finished Project
    Car Hacking
    WorkBlog
    Video
  1. Replies: 4
    Last Post: 06-18-2006, 04:18 PM
  2. Trickle of Money makes for a slow build
    By peeaanuut in forum Newbie
    Last Post: 01-16-2006, 09:59 AM
  3. build control in vb.net 2005
    By takissd in forum Coders Corner
    Last Post: 12-13-2005, 02:23 PM
  4. How would you build it?
    By full_bleed in forum Newbie
    Last Post: 07-12-2005, 08:02 PM
