Results 11 to 20 of 26
Thread: cold temperature outside...
  1. #11
    Jan 2009
    how do you configure the pc to stard just when you put the key in?
    now my computer is starting when i use my remote starter
  2. #12
    Dec 2008
    your remote pager hopefully has an AUX button. just program that to trip a relay, a relay that actually opens up the switched lead to your power supply. that way, you can start your car then activate the AUX which will disable the computer until your turn the key (turning the key resets the AUX mode so the relay reconnects the switched lead). the 791xv system i have has 3 or 4 aux buttons actually, i can do basically anything i can think of if i wanted to..
    if youre saying your computer starts with your engine right now, and you dont want it that way, just hook a switched 12v line to your REM input on your power supply. preferably, the switched 12v right from your ignition.
  3. #13
    Constant Bitrate leo_bergamo's Avatar
    Apr 2009
    I would love to know what solutions you come across. Here in Michigan we are very close to winter and it can become quit cold here also. Keep us posted!
  4. #14
    Oct 2006
    Quote Originally Posted by justchat_1 View Post
    Not really anything to "test" here the manufacturer already did.
    The screen really isn't much of a problem other then not being able to use it (the remote starter was a good suggestion). But firing up a hard drive in those temperatures can actually cause permanent damage so that may be the thing that needs swapping out. Most regaular hard drives are rated for 5-55°C which would obviously be a problem in the temperatures your dealing with.
    Just look at the specs for a SSD before you buy one but a lot of them are rated -40°C to 70°C. Big difference.
    Goodluck finding ssd with -40C under $1000
    old wheel bearing hd are rated for 0, but they work fine -30 degree.
  5. #15
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    The solution is use a HD that does not have Fluid Dynamic Bearings (FDB), as far as the screen goes let the cabin temp warm it up.
    Plenty of threads already discuss this topic along with suggestions and temp examples for what other people use.... I know as I have posted in several of them.... the search feature works.
    Search "cold temp screen"
    http://www.mp3car.com/vbulletin/gene...computers.html
    Temperature Problems
    TruckinMP3
    Read the FAQ!
  6. #16
    Apr 2009
    Quote Originally Posted by TruckinMP3 View Post
    I could only imagine FDB hard drives are anything modern.
  7. #17
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I've used some non FDB drives (very slow too) and even some of them dont work well in the cold either. Long term effects of using a FBD in the cold is unknown. But Ive read that in special automotive grade drives, they design the drives for the cold and heat using special materials and sensors which can compensate head fly heights and other stuff based on temperature, that normal drives dont have.
    It's not just the mechanical stuff that can fail, but even solid state components like capacitors (which can lead to motherboard not POSTing). There is no one single solution. When designing the carpc, youve got to consider everything. LCD, hdd, motherboard, devices, power supply, etc... Use stuff with lower operating temperatures and crucial components (like motherboard) that have solid state capacitors.
  8. #18
    Apr 2009
    Quote Originally Posted by nobb View Post
    Would allowing the vehicle cabin temperature to come up to where it is comfortable to people suffice before turning on the system ?
  9. #19
    Jan 2009
    i'd like something that i can put on the ignition ..or on the 12 volt wires ...wich will allow to pc to boot when the pc will be above 5 degrees.....
    is there anything i can use?
  10. #20
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Quote Originally Posted by leo_bergamo View Post
    Depending on how cold it is, it could take a really long time. If it's -40C, it probably takes 5-10 min for the cabin just to get warm. Then I would estimate it to take another 10-15 min for the carpc to warm up from that. So it could take 15-25 min just for the carpc to be warm enough to boot. By that time your trip will is close to being over. This is assuming the carpc is installed in the cabin. If it's installed in the trunk, you are probably out of luck.
  1. Replies: 3
    Last Post: 04-13-2007, 06:03 AM
  2. Cold temperature preventing POST?
    By BikeBoy24 in forum General Hardware Discussion
    Last Post: 02-26-2006, 09:49 PM
  3. uSDC20D Low Temperature Setting
    By zootjeff in forum Power Supplies
    Last Post: 02-12-2005, 03:50 PM
  4. harddrives withstanding cold temperatures?
    By Nick DC in forum Newbie
    Last Post: 12-11-2004, 10:37 AM
  5. Cold temperature protection circuit?
    By The Grinch in forum General Hardware Discussion
    Last Post: 08-02-2004, 10:06 PM
