Results 1 to 5 of 5
Thread: monitor power cord crapped out
    Feb 2009
    on my Xenarc 700 idt. i was using the one that plugs into the cig lighter and it just decided to stop working. i tested the monitor and the cig lighter and both are good.
    any ideas as to where i can get another one of those?
    or if someone could tell me how to hardwire it into my vehicle as i lost the manual for it
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    Im betting there a fuse inside the barrel of the lighter plug. If not I had the same issue with a liliput and had to cut the end off and inside there was a red and black wire.. the plug had split in it from removal and install alot..hope this help
    the end of the barrel should unscrew and out comes a tube fuse which im almost certain is blown.
    Did it.. Done it... now I got to keep the neighbors kids away!!
    Feb 2009
    i didnt look so i dont know of its the fuse or not but, if it is why would it blow?
    i ended up buying one of those universal ones from radioshack for 16 dollars
    Aug 2008
    it could blow for many rmber reasons. but it always boils down to too much draw. its possible it has a split in wire and shorted the fuse. IM guessing the new barrel plug worked. Either way glad it was a easy fix.
    Feb 2009
    yup good to go thanks for your help
  1. Where to find high quality Aux shielded patch cord?
    By audiology in forum General MP3Car Discussion
    Last Post: 12-20-2007, 10:34 PM
  2. Power Cord question
    By Speg in forum Power Supplies
    Last Post: 05-19-2005, 09:22 AM
  3. Lilliput Cord
    By tczbu in forum General Hardware Discussion
    Last Post: 01-25-2005, 01:24 PM
  4. tsv700 DigitalWW in-dash power cord connection question
    By TheBigDog in forum General Hardware Discussion
    Last Post: 08-30-2004, 08:40 PM
  5. How to wire a laptop lcd to vga cord?
    By acebrooks44 in forum Newbie
    Last Post: 10-09-2003, 09:13 PM
