Results 1 to 4 of 4
Thread: line that's on while engine cranking?
    Oct 2009
    Unhappy line that's on while engine cranking?
    hello, I hacked a relay into to my power button on my laptop but while testing it I noticed the ACC cable doesn't have power when the car is cranking.
    the means as the turn the car on I go past ACC and the ON position which closes the relay, starting the computer. then the engine cranks which opens the relay (computer still starting) then the key goes back to the on position which closes the relay again causing the computer to shut down again.
    do you guys hook up your carputers without this problem?
    thanks!
    -Dan
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Get a time delay relay and set it for about 5 seconds.
    Want to:
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    you can hook it up to the IGN wire on the key. that will be on while cranking.
    Oct 2009
    I was toying around with things and noticed the passenger airbag disabled light comes on for about 2-3 seconds after the car is started. it's illegal to have anyone under the age of 12 in the front seat around here because of the airbag risk anyways so I think I will tap into that line is disable that annoying bulb at the same time
    thanks for your help! The 5 second delay would be ideal so it would work with acc instead of having to start the car before turning it off to acc but I think I will wait on that option
    thanks again!
  1. Headphone vs line level outputs from computer, etc.
    By timeshifter in forum Car Audio
    Last Post: 12-31-2006, 01:21 PM
  2. Noob Questions: Turning Off Media Engine
    By FiReToY in forum Media Engine
    Last Post: 01-01-2005, 08:36 AM
  3. Battery capacity and cranking survival
    By MatrixPC in forum Power Supplies
    Last Post: 12-11-2004, 02:46 AM
  4. Techies - matching line output levels ???
    By slushieken in forum Car Audio
    Last Post: 09-10-2004, 04:57 PM
  5. Replies: 4
    Last Post: 06-29-2004, 09:20 PM
